You could try : - 00800-659 6787. They should be able to help you get instruction manual in English.
Best wishes
Check if in settings you have something like: lokalizacja (location) or jezyk (language) and change from "polski" to english "angielski"
Changing the display language
You can change the language used for the on-screen display and error messages from
ENGLISH to another language.
MENU
Use ac to select the language you want to use.
• You can add another language to your camera with the provided OLYMPUS Master software.
For details, refer to Help in OLYMPUS Master software. g “Using the OLYMPUS Master
software”
SOURCE: instruction manual for suzuki grand vitara 2004, xl7, V6 needed!!
Hope This helps you.
Suzuki
To order Suzuki service manuals, contact:
Helm, Inc.
Manual Distribution Department
P.O. Box 07280
Detroit, MI 48207
(800) 782-4356
(313) 865-5000
fax: (313) 865-5927
SOURCE: Olympus E510, Flash Flicker
If you are in a low lit area with the camera dial set to Auto the flash will do a strobing type of flash trying to help allow more light into the scene. This is called the AF illuminator function. To just go ahead and take the image, put the camera dial to P (program Auto) go to Menu - go to Wrench 1 tab - then right arrow over and then down arrow to AF Illum - right arrow and turn this function from On to Off and then take the image in the P mode setting. No flash flicker should occur.
SOURCE: Olympus e510 hot-shoe doesn't respond...
Have you tried cleaning the hot shoe contact? If the contact is dirty it may not communicate with the camera. The "contact" Its the metal "circle" in the middle of the hot shoe. Using a pencil eraser, rub the contact gently until you create eraser crumbs, then gently rub the "circle" with a soft cloth. See if this fixes it.
SOURCE: Olympus FL36 flash unit
Hey I have an E510 and an fl 36 flash unit and no problems for a year now.
And no problems at all {knock wood]!
Have you checked to see if all the flash pins are making contact?
Normally I only turn my flash on after I put it on the camera and then turn the camera off and then on again to see if everything is ok. I remember the flash would not communicate with the camera on a shoot and after a while I realized that the flash was not all the way in the hot shoe. Fool around with the flash off the camera first and see. The flash have modes that you have to set up if the mode is set in full manual that might be a problem. There is a button that you have to hold down for three seconds to get in the menu, Get hold of your manual or download one My buttons are fine and have not faded any at all. I realize that the power button an the flash is hard to press on, I do hope I was of help .GOOD LUCK
From Chris
SOURCE: Sorry, I don`t speak english. I have two p...
the p0301 and is the same as the p0302 could be wires or plugs if u did that take the neg cable off for 20 mins u might have to do that a few times
