SOURCE: seeburg jukebox sx 100 scans twice and returns
THIS JUKEBOX IS 40 YEARS OLD. LUBRICATION MAY BE THE PROBLEM. HERE IS HOW TO FORCE THE SEEBURG JUKEBOX TO PICK UP A RECORD AND PLAY A SONG.
LOOK AT THE ARM THAT HOLDS UP THE NEEDLE AND CARTAGE. NEAR THE MIDDLE OF THE RED ARM, ONE INCH TOWARD THE MOTOR, THERE IS A HORIZONTAL LEAVER LIFT IT UP A RECORD WILL GO INTO THE HEAD, THAT RECORD SHOULD PLAY THE SONG, IF THE LUBRICATION IS OK.
IF THE RECORD GOES INTO THE HEAD, AND THEN PUTS THE RECORD BACK IN THE RACK. YOU HAVE A LUBRICATION PROBLEM.
THAT IS A TOUGHT MACHINE TO FIX IOF YOU ARE NOT FAMILIAR WITH IT.
DOCTOR FIX IT.
SOURCE: my seeburg disc jukebox skips a lot
try going into service mode to find the problem could be different things also you could try cleaning the laser this is one of the easy options
Rotate by hand till shaft actually receives lubricant especially if you did not remove the turntable to apply the lube 1960 model all oil dried up contaminated with dust of 57 years
Testimonial: "Thanks I'll give it a try."
