SOURCE: Advent tv/dvd 27 inch flat screen. Weird Cable and power and volume problem
I have read that if you unplug the unit for more than about 4 hours, it will reset to the factory settings, and that wont be a problem.
this is at:
http://www.remotecentral.com/cgi-bin/mboard/rc-remote/thread.cgi?7770,1
I quote one guys fix below:
JazzyDaveNew Member
November 2008
View Profile
The factury remote that came
with my 20" Advent lost many of it's functions. I recently purchased
the Phillips Remote SRU4105WM/17 and it works perfectly with the Advent
as well as my other equioment. Buy has it fo $8: http://www.buy.com/retail/product.asp?sku=208673201
SOURCE: Proscan 26LB30Q Vs PS2 = HELP
The red white and yellow cables are composite connections. The red/green/blue connections are component connections.
The playstation's composite connections consist of two audio connections- red & white, and a composite yellow video connection. The TV's white connection is the audio, and the red/green/blue are component video. You need an adapter that will connect the one yellow(composite video) to the three red/green/blue (component video) connections
SOURCE: Proscan 32LB30Q - Troubleshooting
Costco has one of the most liberal return policies around. Simply take it back and get your money back telling them "it doesn't work" as long as you have had it less than a year. Then buy a different brand. You might try calling for customer support from the different brand before you buy.
JG in AZ
SOURCE: Barely hear music from ipod when connected in aux Alpine CDA9835
Are you connecting the ipod through the green that is sticking out the back of the unit? If this is the case this is the amp output. I first hooked my ipod to this and has the same problem you describe. You actually need to purchase this part KCA-121B-Auxiliary-Input-Adapter.html">http://www.crutchfield.com/S-a7wrrbtQT1B/p_500KCA121B/Alpine-KCA-121B-Auxiliary-Input-Adapter.html in order to hook up your ipod up.
