Question about Hoshizaki Freezers
Hoshizaki ice machine under the counter I have heat exchange when first kicks on but when the fan kicks in I lose all heat exchange
2 Suggested Answers
6ya staff
SOURCE:
calebbrunson
Caleb Brunson
  • 54 Answers
SOURCE: Freezer Commercial Ice Machines - KM900MRH Commercial Ice Machine: my hoshizaki under the counter ice machine gradual...
Check condenser coil which is the coil on back with fins, sometimes with metal.mesh filter. If dirty or clogged up clean filter, blow out with air or brush and rinse out, careful not to bend fins. Sounds like issue to me. Unless the dump valve may be leaking by
Posted on Oct 25, 2016
Hoshizaki IM130 ice machine that will not freeze,the coil wire (i think)used to heat up and now not any more? Have pressed the reset button and the same issue remains, water running just not freezing.
http://www.hoshizaki.com/docs/manuals/IM-130_132_210_212_serv.pdf
this web site from Hoshizaki does not show or indicate any wire for heating. See sequence on page 10. You may want to read thru this as this may help you understand how it works and what you may need to address. Let me know if I can be of any further help.
May 31, 2018 | Hoshizaki Freezers
Hoshizaki freezer stuck in defrost
most likely a fan not running or a bad defrost timmer. open door, press in and door switches and Feel or listen for a fan.. it is normal for ice to start to build on evaperator, this must be melted by a electric heating element when in its defrost mode..
Feb 01, 2014 | Hoshizaki Freezers
I have general electric chest freezer that is over heating what can be the cost of the problem
if it has a condensor coil and running fan try cleaning them and leave wall gap for air flow
Sep 17, 2013 | Hoshizaki Freezer Commercial Ice Machines...
Making noise while running
most likely a $450 water pump. or if it is not a remote condensor unit and has a fan then hopefully its only a $35 fix. I have seen the fan blades crack near the hubs ..
Sep 01, 2013 | Hoshizaki Freezer Commercial Ice Machines...
Why is my ice machine compressor over heating
usually from not enough refrigerant in the system. compressor overworking. excessive heat could also be from the compressor being bad such as bad valves. should be checked out by a service tech as this could involve removing freon to make repairs.
Oct 13, 2011 | Hoshizaki Freezer Commercial Ice Machines...
May 18, 2010 | Hoshizaki Freezer Commercial Ice Machines...
Hoshizaki condensor fan motor is not working
Too long to explain sequence here. but in the harvest mode the fan will not be running. go to hoshizaki.com you will find every thing you need very helpful site . and a clean machine is a happy machine. hope that helps Tom
Jun 28, 2009 | Hoshizaki Freezer Commercial Ice Machines...
Hoshizaki ice machine model KM-250BAF SERVICE MANUAL
km-450mwb hoshizaki problem is machine strate is ok but to long time ice making , not dropping, two beeps every three seconds what problem i don't no pleas help mi
Jul 30, 2008 | Hoshizaki Freezer Commercial Ice Machines...
Machine turns on makes one or two batches of ice and then shuts off
Try cleaning the condensor coils. Check the fan blowing across them. When the compressor is running the fan should be too.
Jun 28, 2008 | Hoshizaki Freezer Commercial Ice Machines...
Freezers Logo
49 people viewed this question
Top Hoshizaki Freezers Experts
Dennis Boxerman
Joe Palazola
John Tripp
John Tripp
Are you a Hoshizaki Freezer Expert? Answer questions, earn points and help others
