A link below with helpful info
https://www.lg.com/ae/support/support-product/lg-F8068QDP
https://www.youtube.com/watch?v=l3AdJIXjOaI
https://www.youtube.com/watch?v=YdWuLw15xhk
https://www.youtube.com/watch?v=u6foWr7Mass
https://www.youtube.com/watch?v=c2VypxOTExI
https://www.youtube.com/watch?v=V3PtXGi7-Zk
SOURCE: Running water
Sounds like your stand-pipe has fell over,located behind machine that the drain hose goes into.This pipe must be vertical,and secure.The top of the washers drain hose loop that goes into the stand-pipe, should be as high as your soap dispenser.If this is not the problem then your water pump must be pumping the water out all the time.Can you hear the pump? If so, some faults can force the washing machine into a constant cycle of filling with cold water and pumping the water away if it thinks the washing machine is overheating (possible faulty thermistor).Hopefully its only your stand-pipe causing the loss of water.Lets know how you get on.Good luck.
SOURCE: ariston margherita washing machine
I have an old Margherita washing machine year 2000, my problem I don't have user's manual. Can you please provide me or teach me how to operate the machine?
Thanks & regards
ray salac
SOURCE: hotpoint wf865 washing machine
to take out of test mode you must turn it on while pressing the start/cancel and on buttons at the same time until dOFF appears.
SOURCE: Our washing machine did not start after completion of a program.
I had the same problem and found the answer from Bosch technical support. Reset the indicator and machine by holding down the start button for about 12 seconds - worked for me.
SOURCE: I can't open the washing machin lg tromm after the washing progra
For replacement parts - head on over to PartSelect.com or
RepairClinic.com and enter in your full model number for a full parts
listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your
unit and great "testimonials" for each part that often times includes
HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original
service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a
step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question##$%
Welcome to fixya
Hello
I have a solution for
this
Press Ok, Accept or
replay so we may get started
Your pre-solution is
coming up shortly
PLEASE
REPLY OR LEAVE COMMENT TO CONFIRM YOU RECEIVED THIS EMAIL
My name is Bruce
