SOURCE: the input button
On some sets you can use the menu button to enter the menu and navigate to the page which shows what input is currently selected and change it there. If your set does not have that option, then you will need the remote to do it. I have found that on some universal remotes, the TV/VCR button switches the inputs on the TV when the remote is in the TV mode. If that button does not work on your remote for your set, and you have tried all possible codes for JVC TVs, then the only way to switch inputs is to invest a few dollars more and get an original remote from JVC or have the set repaired so that the input button on the TV functions again.
SOURCE: DVD player reads open and the when I push the play button it reads invalid key
I am having the same issue with Toshiba SD-P1850
SOURCE: Player will not eject disc
Generally this is caused by the software in the machine being poorly programmed and has developed a bug. Try unpluging the device for 24 hours to dissipate the charge and plug it in again. This should reset the software and allow you to eject the disc. If this doesn't work, it is a hardware issue and the device needs servicing or replacing.
SOURCE: connected DVD player to Sanyo DS27930 TV via input
According the manual for this TV the remote control has an input button, it is left of the power button. Make sure that the remote mode slected for TV not VCR or DVD and press input button to make a selction, make sure that the power to the DVD player is on. If yours is different try stepping through the channels buttons, some TVs input is selected through the channel buttons.
SOURCE: MALATA DVD PLAYER I HAVE A DVD PLAYER MODEL DVP-393A SETUP HELP
the code for malata dvd player is 0782 but when i tried it didnt work. i used the code search method and it worked for me. the only problem i have is that the buttons are mixed up for example, the "menu" button opens the disk tray. so far this is the only way i could get it to work with the rca remote.
