SOURCE: Necchi machine
Bu Mira was made in Italy between 1952-1956 it was the machine where the introduced the Wonder Wheel to make decorative stitches, olive green in color . There are some people who collect them but like all antiques the rearer the are and the better origonal condition the are in the more the are worth.
SOURCE: making a buttonhole on a Necchi 3204 sewing machine
Here's what the manual says:
Before sewing, fit the button-hold foot to the machine (long white plastic thing with red, ruler like markings).
Select the pattern selector dial that is solid green on the left hand side. Set the dial to "1" position. Sew the left side and raise the needle.
Select the pattern selector dial that is solid green on the top and bottom. Set the dial to "2" position. Sew 5-6 stitches and raise the needle.
Select the pattern selector dial that is solid green on the right hand side. Set the dial to "3" position. Sew the right side. Raise the needle.
Select the pattern selector dial that is solid green on the top and bottom. Set the dial to "4" position. Sew 5-6 stitches and raise the needle.
Hope that helps...
SOURCE: manual fornecchi-alco sewing machine model 301
I have an ALCO 2200. Luckily I have the manual. If some one need the manual, I can photocopy and send it to you, if you do not mind paying the postage. :)
SOURCE: I need a user manual for a Necchi Alco 2200 sewing machine
Contact the individual who posted this answer.
You should also try www.sewusa.com. I found the manual for a used Necchi 521FB I brought. Hope that helps.
Stephanie, in my opinion, yes it is worth trying to use it. I have one and they are good solid machines. You can find the manual reasonably price by internet search. In addition .i am sending you a link for a ‘general’ service repair manual, which has much of what you need, such as how to thread it, bobbin work, etc. it does not say specifically that it is for a 3204fb, but it maybe exactly or close enough.https://freenecchisewingmachinefiles.wee...
