SOURCE: scanning document leaves streak down right hand side
Backu
Thanks for the tip...the problem is NOT a black line but a wide yellow line on the right side of the paper. It starts out about a quarter of the page in width and diminishes in size to about a half inch in width after many repeated scans.
The glass IS clean , and even when the glass had some smudges here and there, I never had a yellow stripe problem!
Scanner bulb is bright and even the entire length of bulb (no dark areas) so I don't think it is the bulb!
Rowboat
SOURCE: Scan copy to computer
Here is what you do... There is a newer utility then the one that came with your scanner.
Please follow the steps below to do a clean installation of your scanner.
The first thing we need to do is remove any files that have been installed and start with a fresh installation.
1) RIGHT-CLICK on the MY COMPUTER icon and click on PROPERTIES.
2) Select the HARDWARE tab, then the DEVICE MANAGER button.
3) Remove the Epson Scanner from under IMAGING DEVICE and/or UNKNOWN and/or OTHER DEVICES by RIGHT-CLICKING on it and clicking UNINSTALL.
4) Disconnect the USB cable and close all open windows.
5) Click on START, and CONTROL PANELS.
6) Double-click on ADD/REMOVE PROGRAMS. Highlight EPSON SCAN and click on CHANGE/REMOVE.
7) Restart your computer.
DOWNLOAD
Please follow the steps below to download and install your scanner in XP:
1. Go to the website http://support.epson.com
2. Under the SCANNERS heading select PERFECTION SERIES and then your scanner model.
3. Under the Drivers & Downloads section select Windows.(Make sure it is the Epson Scan utility. Download the most current version of the Scanner Driver for your Windows operating system to your DESKTOP.
Reinstall
1) Double Click on the Epson1****.exe file that you downloaded to your DESKTOP.
2) Click OK, Unzip, and then OK again.
3) The installer will copy the files to the system. Click on FINISH when prompted.
4) Connect the USB cable. Windows will tell you new hardware is found and complete the install.
5) If a message appears indicating THE SCANNER HAS NOT PASSED WINDOWS LOGO TESTING, click CONTINUE ANYWAY. Then click FINISH.
6) Your scanner is now ready to use.
Use the following steps to scan with the Epson Scan utility:
1. Open Epson Scan by going into START, PROGRAMS, and EPSON SCAN.
2. If prompted, select your scanner from the list of models and click OK.
3. In the FILE SAVE SETTINGS window, you can designate the location, name and type of file the scans will be saved as.
-LOCATION defaults to MY DOCUMENTS. Click BROWSE if you wish to change this.
-PREFIX determines how the scan will be named. Type any name you like. You can also designate a start number.
-FILE TYPE dictates what format the scans will be saved in. ie. .JPG, .TIFF, .PDF, or .PICT)
-For example: if the prefix is "img", the start number is "1", and the format is "JPG", the name of the file saved in
PICTURES will be "IMG001.JPG". More settings for file format are found under OPTIONS.
4. Click OK once settings are changed as desired.
5. The EPSON SCAN window will open and begin scanning in FULL AUTO MODE. In FULL AUTO MODE the software makes all the decisions for you (as to what is being scanned, where it is on the flatbed, etc). This is the easiest way to scan.
6. If you want full control over the scanning process click PAUSE and change FULL AUTO MODE to HOME MODE or PROFESSIONAL MODE. In the latter two modes you can change your scan settings as desired. Click SCAN after you have selected your settings. Click CLOSE once the EPSON SCAN is finished scanning.
7. When scanning is complete, your images will be saved in the location specified on FILE SAVE SETTINGS, with the prefix and in the format you set.
SOURCE: Solid Line on left Margin after Copy/Scan
When I Copy or Scan with my HP LaserJet 3050, a solid black line appears on the left margin of the page. . Can you suggest any solution to the problem. .
SOURCE: Message says "Scanner Failure" and "Unable to scan or copy"
Obviously its scanner error,the whole scanner assembly needs replacement.It could be the bulb or the scanner board, but upon replacing it needs both.
SOURCE: Samsung SCX-4720F reads "SCANNER LOCKED" and won't copy or scan.
the lock is underneath the scanner where the printed paper gets delivered. when you reach in to get a printout you more than likley have pushed it into the lock position. Once you unlock that blue button by pulling towards you, switch off the printer and again switch on the printer.
