Cell Phones Logo
jamie zemp Posted on Nov 01, 2019
Free unlock code for a LG Aristo 2 PLUS - LG Cell Phones
Ckaizer Martin
Level 1:
Night Owl:
An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • Contributor 32 Answers
  • Posted on Nov 08, 2019
Ckaizer Martin
Contributor
Level 1:
Night Owl:
Answers
32
Questions
0
Helped
3805
Points
63
SIM unlock phone
  1. Determine if devices are eligible to be unlocked: Mobile Wireless Device Unlocking.
  2. From any home screen, swipe left to locate and tap T-Mobile folder > Device Unlock.
  3. Tap Continue.
  4. Wait while the device connects to the server.
  5. Choose the desired device unlock type:
    • Permanent Unlock: Permanently unlocks the device.
    • Temporary Unlock: Temporarily unlocks device for 30 days. Temporary unlocks must be performed with a mobile data connection. Wi-Fi will not work.
  6. Wait while the device requests the unlock.
  7. If successful, restart the device to apply the settings.
  8. You will have a persistent alert in the notification tray until you restart the device.
5 Related Answers
jaffa012001
L Jefferson
  • 376 Answers
  • Posted on Oct 19, 2008
SOURCE: region free unlocking code for LG RH2T80 DVD Recorder
Goto 'Setup'
Scroll to 'Lock' (don't scroll sideways from here)
press '0' seven times
press 'Enter'
Anonymous
  • Posted on Jul 13, 2010
SOURCE: I WANT FREE UNLOCK CODE FOR LG 0168 MOBILE PHONE
give me
Anonymous
  • 151 Answers
  • Posted on Jun 03, 2011
SOURCE: at&t lg prime gs390 free unlock codes
Please see below instructions in details on how to unlock code for LG phones, (i have included various model of LG for you to try)
Here are some unlock codes for AT&T LG phone available, menawhile , including the methods of entering the Unlock Code on your LG phones attached to them. Hope this is useful. AT&T cell phone Questions&Answetrs
Model : AT&T LG VU CU915 & CU920
1. Put a AT&T or Cingular SIM in the phone; it does not have to be an active SIM 2. Enter *#865625# then the 16 digit unlock code 3. Device should say: Network Lock Deactivated 4. Phone may automatically reboot and is now unlocked !
Model :AT&T LG C2000
Insert non-Cingular SIM card Power on the handset - phone will display "phone restricted" Select "Cancel" - phone will display "phone restriction code" Enter the SIM Unlock code. Select "OK" - the handset is now successfully unlocked
Model : LG TU720 - LG CU720 and all LG Shine SERIES
1) Power ON your phone with an accepted SIM card 2) Type *#865625#UNLOCK CODE 3) Press OK 4) Device is now unlocked
Model : LG CE110
1) Put a non AT&T or Cingular SIM in the phone; 2) The phone display: Invalid Smart Chip 3) Power on handset 4) Select "Cancel" - phone displays "phone restriction code" 5) Enter the unlock code (8 digit code*) 6) Select "OK'" - the handset is successfully unlocked
Model : LG CU400
1 - Insert non-Cingular SIM card" 2 - Power on the handset - Phone will display "Invalid SmartChip" 3 - Phone will display "Invalid SmartChip" 4 - Enter 159753#*# 5 - Enter the 8 digit SIM Unlock code 6 - Select "OK" 7 - The handset is now successfully unlocked
Model : LG CU500
1 - Insert non-Cingular SIM card" 2 - Power on the handset - Phone will display "Invalid SmartChip" (IF THE PHONE DOES NOT DISPLAY INVALID SMARTCHIP, PLEASE POWER OFF AND ON AGAIN) 3 - In Idle screen, enter 159753#*#. Phone will display "Enter NCK, Remaining 5 4 - Enter the 8 digit SIM Unlock code 5 - Select "OK" 6 - The handset is now successfully unlocked
How to Unlock LG CU515:
1-Insert non-Cingular SIM card" 2-Power on the handset - Phone will display "Invalid SmartChip". 3-Enter *#865625# then select option 1 and then again select 1 4-Enter the 16 digit SIM Unlock code 5-Device should say: Network Lock Deactivated 6-The handset is unlocked. 7-How to Enter Unlock Codes on CU575 (Trax) How to Enter Unlock Codes on LG F2250:
1-With allowed sim card in the start menu type: 2945#*3311#. 2-Handset shows saved, then return to startup screen 3-Press Menu key, choose Settings > Security > Sim Lock> Network > Deactivate, handset will now show 'Enter NCK' 4-Enter your unlock code and OK. How to Enter Unlock Codes on LG U8110:
1-With a not allowed sim card in your phone enter Pin code then validate, type: 277634#*# 2-Select 'Sim Unlock' menu # 3-Enter NCK code then validate 4-Your phone is now unlocked. How to Enter Unlock Codes on LG U8210:
1-With a not allowed sim card enter Pin code then validate, type: 277634#*# 2-Shows test menu 3-Choose sim test menu and type: 2945#*#, choose Sim Unlock menu 4-Handset shows 'Enter NCK' 5-Enter code, then hit OK. How to Enter Unlock Codes on LG U81xx:
1-To bring up the unlock menu on the phone with a SIM card, type 2945#*88110# 2-Enter the code 3-In case you need to reset the phone without a SIM card first, type 277634#*# or 47328545454#. If your cell phone is not listed, please follow instructions for LG C2000 above
If If instruction above does not help you i would strogly suggest to contact your Service Provider to provide some alternatives.
Thank you for using fixya
Please rate me and give testimonials if ever to continue my assistance
lg-phones
Matsu
  • 385 Answers
  • Posted on Jun 10, 2012
SOURCE: need free unlock code for rogers lg thrill p925
Hi, I doubt you can get it for free but you can probably use a cheap solution available here: http://www.fastgsm.com/en/lg/lg/optimus-3d-p920/unlock-code-usim-locked
Anonymous
  • 32281 Answers
  • Posted on Aug 31, 2012
SOURCE: free unlock code for LG A133
Unlock Cell Phones
Your cell phone may be locked to a particular cell phone provider and in this case it needs to be unlocked to use with a different cell phone service provider. To get the security code/restriction code to unlock the cell phone from the current cell phone provider so you can use the SIM card with a different phone provider, Please click on this link and follow my instructions :- http://www.fixya.com/support/r4049238-unlock_cell_phone
If your phone provider does not help you then these WEB sites it provides security codes for a small price. http://www.mobileunlockstore.com/?gclid=CKDb2_y2558CFSlJagodxBkDHw http://www.mobileunlocksolutions.com/ http://www.superunlockcodes.com http://unlockcellphonecode.com/
Can you guys give me the Secured Start Up Codes gor my L.G. Xpression Plus 2
PUK codes can only come from the Telco that owns the phone.
LG Xpression Plus 2 (LM-X420AS8) - Secure My Device - AT&T
www.att.com > device-support > article > wireless > LG
Sep 20, 2019 - Get LG Xpression Plus 2 (LM-X420AS8) support for the topic: Secure My Device. ... get your PUK code, or request your device be unlocked from the ... the desired screen lock type and follow the prompts to complete set up.
I have forgotten the security password for my LG Xpression ...
www.hardreset.info > lg > lg-xpression-plus-2 > faq > faq
I have forgotten the security password for my LG Xpression Plus 2. What should I do? Just make ... How to Install & Launch GameBoy Games on your LG Xpression Plus 2? ... I have forgotten a PIN code for LG Xpression Plus 2. What should I ...
Help library: Secure start-up on smart phone ' LG U.K.
www.lg.com > HOME > Support
Aug 1, 2017 - This function is activated when "Enable" is checked on the following screen when setting lock screen or "Secure start-up" in security setting. If a ...
Jan 06, 2021 • Cell Phones
Unlocking my metro pcs lg aristo 3+ network unlock
All phone shops are able to do this for you!
Is there a way to get the fitplay app to work on my LG Aristo 2
Apps work based on the version of Android that your mobile device is running. You can make sure your Aristo 2 is running the latest version, but if the app requires a later version of Android than your phone can run, you can't use the app.
Openline lg ku250
To oepnline LG KU250 or Unlock it visit the site
Onlinegsmunlock.com/lg/rs7wp8/ get the Unlock code at reasonable cost and Unlock it easily..
How to openline
To Openline LG KU250 get the unlock code from the site
Onlinegsmunlock.com/lg-ku250/rs7wp9/ and unlock (openline) from network lock.....
Unlock code for lg shine plus
At free of cost is not possible for your mobile so you do not worry about this one you can get a code at a reasonable cost itself........Get the unlock code for your LG Shine model mobile here http://www.mobile-unlocker.com/lg-shine/rs2wp9/ , it gives easy instructions for getting the unlock code for your mobile from the network lock........
Top LG Cell Phones Experts
vince
Steve Sweetleaf
Steve Sweetleaf
nexrad_chris
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
