Question about RCA Televison & Video
My RCA RLDED3956A TV's picture is too large for the screen but there is no "FIT TO SCREEN" or "DISABLE OVERSCAN" option. Neither of the four aspec-ratios fit correctly.
    Top Expert:
  • RCA Master
  • 10,627 Answers
Try picture or tv set up and change view
Posted on Dec 18, 2019
6ya staff
SOURCE:
Orlando Labra
  • 93 Answers
SOURCE: JVC AV2649S Picture Too Large
you can see the diagnostic menu in jvc as you press both at the same the display and the picture mode buttons
Posted on Oct 18, 2007
Anonymous
  • 84 Answers
SOURCE: Picture width is too large for my screen
look for horizontal control
Posted on Oct 19, 2008
Anonymous
SOURCE: Picture is too big for screen
Go into the setup menu of the TV, and you'll find a category called DISPLAY or ZOOM. That's where you can change the aspect ratio so that it fits on the screen. You'll probably get a gray band on the top and bottom of the screen due to the re-sizing.
Posted on Dec 20, 2008
Anonymous
SOURCE: Sony Bravia - picture don't fit the screen
if youre using skybox or freeview make sure the auto format setting is switched off. youl find this in your menue setting
Posted on Jan 05, 2009
Anonymous
I have a Scientific Atlanta cable box w/ Time Warner. I followed the instructions below for the cable box. Somehow it reset my picture and I can now read the ticker at the bottom of the screen and the different picture sizes seem to work properly. Good Luck.
http://newteevee.com/2007/12/15/six-steps-to-get-more-hd-from-your-scientific-atlanta-set-top-box/
Posted on Jan 31, 2009
How do I adjust tv screen size to fit laptop? lap top projection is to large for operating properly. to big.
Assuming you have a flat screen 16x9 TV, make sure it is set to screen fit so that there is minimal overscan. The button should be called pic size or aspect ratio. Also set your laptop to the same resolution as your TV or as close as possible to a supported resolution.
Feb 02, 2018 | Televison & Video
I have a TH-50PY700H TV linked to an M8S KitKat 4.4.2 Kodi TV Box but the top & bottom of the display is cut off. Can anyone help pls.
If the signal is a product of the ott box than go to settings and find display. It will tell you how to make screen size to fit your screen.
Aug 19, 2017 | TV Box Televison & Video
Screen zoomed in zoom out
Go to Display settings and make sure Auto Detect is off.
Then if it's off or after reset go to HDTV settings and select 1920x1080, if there is no picture wait till it comes back and select 1360x768. Just keep going down till you find one that works.
It's a bit of a bummer some TV's out there have no option to disable the overscan. Also a bigger shame that a lot of TV's are sold as 1080p yet only have a 1366x768 native resolution.
However this solution should fix overscan issues if it can't be done through the TV.
- Answer Found on http://forums.xbox.com posted by sn1p3t sk33t
I’m happy to help further over the phone at https://www.6ya.com/expert/paul_0af9b1d5c0eb4fc3
Apr 08, 2014 | Hannspree Computers & Internet
Pc resolution doesnt fit on screen
There is probably an overscan option in the TV menu. Make sure that is off. Otherwise, adjust the resolution on the computer to fit correctly.
Mar 28, 2014 | Hitachi P42H401 42 in. Plasma HDTV
White stripe on screen
Unfortunately it seems that each time I turn the tv on and off it resets the screen position and I have to adjust it each time.
I would assume that my set would remember the settings.
Use Picture Size, not Picture fit. Set it to 16:9, instead of Fit To Screen. There's a handy button the the remote for this: P-Size. And the setting sticks between shut-offs.
What you are seeing is called "overscan", extra information that most broadcast stations send, because most old TV's were set to zoom-in/crop the signal they received. So.. with new TVs, like your Samsung, you get the choice between size "Fit to Screen" which is 1-to-1, for pixel-accurate inputs like Blu-Ray and DVD, and size "16:9" which is really "support for overscan", for old, less precise signals like broadcast.
Mustang Parts.
May 28, 2012 | Samsung Televison & Video
Panasonic viera doesn't display computer correctly
I have had what is fundamentally the same problem. I have a desktop PC that I am plugging in to my Panasonic Viera TX-32LZD80. I am using DVI connection plugged in to HDMI port.
The solution is fairly simple; use the Menu button on the TV remote to get to the Main Menu for the TV and then select Setup which should be the fourth of four options. This will get you to the Setup Menu for the TV for the current channel. Look for the Picture Overscan option, it will very probably be set to On if you have the problem of %5 or so of display being missing on all sides.
Switch Picture Overscan to Off.
This immediately should solve your problem. A note of warning on this is that I suspected this was the problem but when I first looked at the Setup Menu I could not find the Picture Overscan option.
If you are unable to find the Picture Overscan option then trying fiddling with the Aspect settings. You will probably find it set to Auto. Switch it to 16:9 and you should find the Picture Overscan option will be available from the Setup Menu.
Hope it works for you.
Mar 03, 2009 | Televison & Video
Sanyo 42" 1080p, picture doesn't fit on screen
this is normal and this feature is for wide screen programs! normal shows and games will lose part of the top of the screen sides and bottem because it zooms in on whats in the middle of screen! hope this helps
Dec 07, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
PICTURE TO LARGE FOR THE SCREEN AND ZOOM ISNT FIXING IT
Your TV set may have settings for picture size ratios but also if you have cable or sattelite service, they too may have these settings. Try both TV and cable remocons for proper adjustment
Jul 26, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Televison & Video Logo
Top RCA Televison & Video Experts
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
