SOURCE: what is the gap for the ignition module on a
A thin business card is just right for setting the gap. Turn the magnets to be under the module poles, loosen the module screws and allow it to stick to the magnets. Tighten the screws, rotate the magnets away and remove the card. If the module is good it should make a snappy blue spark with a new plug. If rotating the flywheel through one revolution causes any core rubbing, the crankshaft may be bent or the flywheel may not be fully seated on the crank shaft. Don't run the engine until this problem is repaired. Hope this helps!
