Question about Lands Phones
When I try to turn the DND off, the phone rings twice constantly until I turn DND on.
6ya staff
SOURCE:
Anonymous
  • 3 Answers
SOURCE: Can't remove DND off display
press the [world] setting button, then choose settings
choose call preferences.
change DO Not Disturb to NO
press save (middle button)
press back
press exit
johanvt
Posted on Aug 26, 2008
Anonymous
  • 38 Answers
SOURCE: DND button will not turn off
Depending on how your system is programmed, you might be able to turn it off by pressing it. Otherwise, you might have to press it and dial a code number, which also can vary from one installation to another, but I would try "0"
Otherwise, it can be programatically corrected by your installer if the system got "stuck" or something.
We have a support package that allows us to make all the changes you need over the Internet for a flat annual fee. If you want your whole system to work properly and all changes to be made for you at a flat budget, call us at 877-236-8376.
Posted on Oct 14, 2008
Anonymous
SOURCE: How do you disable DND on NEC Dterm 80 phone WITHOUT DND button
Feature 69 feature
Posted on Apr 01, 2009
Anonymous
SOURCE: HTC Touch Pro only rings twice before switching to voicemail
I think the issue is a misconception on the operation of the phone. The phone flashes for the first ring, vibrates for the second ring, and then rings for the 3rd and 4th ring before dropping to voicemail. it requires a registry modification as can be found on some forums to make it "ring immediately." If you put the phone on vibrate it will buzz immediately and skip the flashing lights step.
Posted on May 21, 2009
Anonymous
SOURCE: Cisco ip phone 7940 does not ring for incoming calls.
It sounds like you have enabled Do No Disturb accidently. This can be turned on and off by pressing the DND softkey button along the bottom of the LCD display. You might need to press the 'more' softkey to display all options.
Posted on Sep 24, 2009
How to turn ringer on
There are two possible reasons for the handsets not to ring when they are functioning properly. 1) You have the ring volume set to off. This would be done on each handset. With the phone in standby, press the volume up button until you reach the desired ring volume.
(There are 4 volume levels.)
2) You have toggled on the Do Not Disturb feature; this will apply to all of the handsets when started on one handset. Press and hold the # key (below 9) on a handset that is in standby. You should release the key when the phone stops showing the DND symbol. You can actually set the length of time in hours for the DND feature by pressing a number key (1-9) when the screen shows a prompt. If you don't press a number key within 5 seconds, the DND remains on until you press and hold the # key again.
If neither of the above solutions work, you need to check that the base is receiving calls properly. Check if a different phone (preferably a basic wired phone) rings properly when you get an incoming call. If another phone doesn't work, you'll need to check your wiring. If another phone works, contact Uniden if the XDECT8015 is under warranty.
Uniden has the manual for the XDECT8015 on the product page: http://www.uniden.com.au/australia/p_xdect8015_1_index.asp . The direct link is http://www.uniden.com.au/RESOURCES_MAIN/pdfs/XDECT_8015_1_OM.pdf .
I hope this helps.
Oct 03, 2014 | Lands Phones
How to disable do not disturb on NEC Dterm80 phone?
Have a coworker call your extension to see if DND is on, they will go straight to voicemail or get a fast busy. Speaker 42 may be the default cancel DND code, depending on your system and whether the codes were changed. Anyway, ringing is set up in system programming. If someone calls your extension it will likely ring, but outside calls have to be assigned to ring in system programming. Usually need a tech to do the programming since it gets complicated very quickly.
Sep 09, 2014 | NEC Dterm DTP 16D-1 Corded Phone
How to turn off ringer at particular extension?
Do Not Disturb (DND)
When DND is enabled, the telephone will not ring when someone calls, but the line
indicator still flashes. In Personal Call Manager, the
You Have a New Call dialog box
still appears and the icon for the call appears in the Calls box.
You can turn the Do Not Disturb (DND) feature on or off from the
Calls menu or the Personal Call Manager icon in the task tray.
Turning DND on or off
To turn DND on or off:
1. Click the Personal Call Manager task tray icon or the
Calls menu.
2. Click the DND menu item.
When DND is on:
• the Personal Call Manager task tray icon changes to
• the symbol check
appears beside the DND menu item on the Calls menu and the
Personal Call Manager task tray menu
• DND appears in Status bar
Oct 23, 2013 | NorStar Meridian M7310 Phone
I have Panasonic KX-T7420s with a TVS50. I have voice mail set up at each extension number. I tried calling from an outside number and transferring to a different extension number to see if I can leave...
Take a look at the manual. One of the bits in programming deals with the status of the FWD/DND button. You can make it light solid for FWD and flash for DND. There are other ways to intercept the calls, but trust me, this is the cleanest. You set 7104 165 # and it will forward always on no answer after x rings. Those rings are set system wide and can be adjusted in programming.
If you sit down wiht the PG manual, pay attentiion to programs 202,203,619 and 990 area 9 bits 3&4. A ring cycle is about 6 seconds and the default intercept is TWELVE rings....you should adjust that to no more that 4.
Car
Dec 27, 2010 | Panasonic KX-T7420 Corded Phone
When I have my DND on or am on a call, I still
You have the button wrong. If DND is on, the phone will not ring.
Apr 06, 2010 | Avaya Corded Phone avaparp18d
Panasonic vb-42211 phone won't ring. How do I
1) Press PROG, follow by programming no. 50 or FWD/DND button.
2) Press ENTER or STORE, follow by selection no. 0=OFF FWD/DND, 1=ON FWD/DND.
3) Press ENTER or STORE to save the setting.
4) Press EXIT or PROG to quit setting mode.
YBC (/\)
Feb 18, 2009 | Panasonic KX-T7633 Corded Phone
Jan 27, 2009 | Cisco 7940 IP Phone
My Phones only ring twice before it goes to VoiceMail
What you can do is go into the management console for your system and find the forwarding this is under extentions option 2 fwd/dnd select your extention number and on the bottom option FWD No Answer Time (s) set it to 10 or more and this will change the number of rings.
I use a KX - TDA600 PABX so I hope this helps
Jan 06, 2009 | Panasonic KX-T7630 Corded Phone
Do Not ring During Meeting
DND (do not disturb) is the only easy way I know of doing this for a short period.
If you do not have a button programmed for DND you can press [FEATURE] 85 to turn DND on or off.
Feb 25, 2008 | Nortel Meridian M7208 Corded Phone
Lands Phones Logo
32 people viewed this question
Top Lands Phones Experts
Ekse
Marvin
Marvin
Are you a Lands Phone Expert? Answer questions, earn points and help others
