My scooter is making a beeping sound after I had usedit and put it on my car liftoff bring home I didn't notice it up until I got home but I cannot find out why. I am 78 and that could be my problem.
If the lights on your Golden 3-wheel scooter won't turn off and you hear a beeping sound after turning it on, it could indicate a potential issue. Here are some troubleshooting steps you can try:
Check the key switch: Ensure that the key is inserted fully into the key switch and turned to the correct position. Sometimes, if the key is not fully engaged or turned properly, it can cause electrical issues. Try removing the key, reinserting it, and turning it to the correct position.
Examine the battery connections: Inspect the battery connections to ensure they are secure and free from corrosion. Loose or corroded connections can affect the scooter's electrical system. If you notice any loose or corroded connections, carefully tighten or clean them as needed.
Verify the charger connection: If the scooter is connected to a charger, make sure it is properly plugged in and connected to the scooter. A loose or faulty charger connection can cause electrical malfunctions. Try unplugging and reconnecting the charger to ensure a secure connection.
Check the scooter's manual: Refer to the owner's manual or user guide for your specific model of Golden 3-wheel scooter. It may provide troubleshooting steps or information about the beeping sound and lights issue you are experiencing. Look for any error codes or indications that can help diagnose the issue
When you activate Siri by holding down the 'home' button there has always been a 'beep' or chime sound, Apple decided we didn't need it any longer....
Everyone I know hates it now.
But if you want to give up your vibrate functionality you can have it back. -Settings, General, Accessibility, Vibration (turn it off). Siri will now beep when activated..
The E-Scooter without being activated will keep beeping when turned on and its speed is limited to 10 km/h. You need to install Mi Home app and follow the on-screen instructions in the app to activate your scooter for the first use. The beeping sound will not stop until the scooter is activated.
Yup. The alarm beeps if you have the charger plugged in and turn on the key even if the battery is flat. The charger won't bring a totally discharged battery up to full charge. You can charge the battery individually using an automotive style battery charger. The charger should NOT be the automatic type. It may take some time to recover a flat battery. Charge it until you can see at least 10 volts on the battery. The scooter charger can then finish up the charge. If after you go through all this and the batteries will not take a charge, then it's battery time.
It seems that something isnt properly seated. Dismantle it and put it together (mantle it?!) very positively this time, make sure the freewheel latch is fully home.
hi, that's sounds like the freewheel lever is engaged, please make sure it out of freewheel mode, now remove the rear axle then refit, does it still make that noise ?
Yes, okay now check the connection from the rear axle to the frame, make sure they are clean and a good connection, Regards www.gewizrepairs.co.uk
