Dryers Logo
Dave mcminn Posted on Oct 31, 2019
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have a cdw60w18 essential the electric trips out when the drying process has run after about 5 minutes
brian williams
Level 3:
Genius:
  • Master 1,980 Answers
  • Posted on Dec 18, 2019
brian williams
Master
Level 3:
Genius:
Answers
1980
Questions
9
Helped
740814
Points
5402
My guess is faulty heating element or high output thermo
5 Related Answers
Anonymous
  • 706 Answers
  • Posted on Jan 03, 2009
SOURCE: CIRCUIT BREAKER TRIPS AFTER 5 MINUTES.
Hello dale210mile,
Based on your problem description, it is possible that your circuit breaker itself is on its way out.. ( they do go bad sometimes) but before going that route, I would make sure that ALL wiring connections are tight ( meaning shut off the circuit breaker and make sure every electrcial tie point is snug and that you don't have a 'high impedance junction' somewhere in the power feed to the dryer. When you say the heating element 'appears' fine.. not sure what that means exactly but depending on the model.. you should be able to measure its cold resistance with an ohm meter and it should fall within manufactures spec.. A visual check of the heating element really won't tell you much unless it has shorted and you see a burn mark on it.. The mere fact that it runs OK for 5 minutes and then trips the breaker leads me to beleive that it may not be ok..but it is important to rule out the other hardware ( wire terminations etc) before going that route. One test you can try.. if after you've checked all the wiring etc..try running the dryer with no laundry in it .. ( just to verify that the additional load that the motor adds to the entire current draw isn't taking it over the top...) Hope these suggestions help you zero in on the solution..
Good Luck
Rick
TheMobilian
Dan Webster
  • 8221 Answers
  • Posted on Feb 14, 2010
SOURCE: Whirlpool Ultimate Care II dryer trips breakers.
No way to know unless you do some checking. This video shows how to get into the machine: HERE
I have a repair manual that features the same basic style of dryer you may want to take a look through: HERE
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Thatvacguy.com
  • 1619 Answers
  • Posted on Jul 21, 2010
SOURCE: trips
The switch could be bad. Make sure there are no clogs anywhere that could be causing it to overheat. Try to bypass the switch and run it just long enough to see if you can go longer than the normal 5 min. you're getting. If you can then replace the trip switch. Do not continue to use the machine without the trip switch operating properly or it could catch on fire.
motor1258
Mike Butler
  • 6674 Answers
  • Posted on Jul 25, 2010
SOURCE: AC runs for 5 minutes and then circuit breaker
What else do you have running on hydro while AC is running? Such as coffee maker, microwave, water heater, fridge. That 30 amp breaker is your main breaker I assume, or breaker on pole your plugged in to. Keep in mind your AC will normally draw approx. 15-17+ amps momentarily when compressor kicks in to cool, then drop back to 12-15 amps when running normal. If your AC is drawing too much current, then you would only normally trip 20 amp breaker for AC in your panel. Try switching other appliances to gas operation while running AC, such as water heater, and fridge. Make sure incoming voltage is up to specs as well . (115-120 volts)
If water heater takes 5-8 amps, and fridge takes same when they are calling for power, you'll be close or over the 20amp mark when you consider your on board converter etc. as well. That only leaves approx 10 amps for AC that requires approx 15 amps to run, and up to 20amps when compressor kicks in. If you switch all those other items over to propane, and it still happens, then a current draw test should be done on AC unit to see if perhaps a capacitor is faulty, or possible compressor faulty.
Gene Haynes
  • 5391 Answers
  • Posted on Nov 01, 2012
SOURCE: breaker trips after bout 5 minutes
Breakers trip because of heat.
When heat from wire exceeds breaker rating, it trips.
Something is causing heat on the wire, wire is too small for the amp draw, there is short circuit, or breaker is bad.
Replace breaker and/or test wire.
Put amp-meter on wire and read amp draw through wire.
Amps cause heat. That's why high voltage lines from power station are high-volt-low-amp so there is no heat loss with long distance transmission, until transformer at home converts electricity to lower volts and high working amps with enough power to run electrical devices.
Same is true for AC and DC circuits.
If amp reading on wire exceeds rating on breaker for length of time, then breaker will trip.
The fact that the breaker lets current (amps) to flow for a period of time before tripping is because the breaker is probably rated for slow-acting, or it takes a while for amp draw to heat the wire.
Following image shows amp-meter that clips over wire to get amp reading.
http://waterheatertimer.org/pdf/Which-is-best-gas-water-heater.pdf
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
2helpful
Why does the dryer cut off after approx 5 minutes
Dryer: Starts then stops. If an electric dryer starts but then stops before the load is dry, a clogged exhaust vent may have caused the dryer to overheat and trip the thermal fuse. ... A bad drive motor, failed timer or faulty electronic control board can also stop the dryer before the cycle ends.
https://www.searspartsdirect.com/diy/symptom/dryer-repair/1234594/starts-then-stops/dryel09
http://www.appliance-repair-it.com/dryer-runs-for-10-minutes-then-quits-it-will-restart.html
May 14, 2020 • Dryers
2answers
I have a cdw60w18 essentials dishwasher. the programme lights p3 and p4 keep flashing. can you help please?
Sounds like blocked filter, its down bottom R.hand side switch off power make sure as little waterin machinebefore starting, then Get a towel unscrew the filter remove blockage/ refit Bobs your uncle....
2helpful
2answers
Breaker trips after bout 5 minutes
Feb 14, 2010 • Dryers
Unit comes on and runs for 5 minutes, the circuit trips off
30 is the correct size breaker for this unit. It sounds like there is a grounding issue going on in the system. Or off of the Thermostat. Something is grounding out causing the switch to trip. Are you running #10 wire to breaker and the unit? If not you will need to increase your wire size
Dryer works and cut off
Sounds like heat over load switch is tripping due to lint build up , check around heating coils for lint build up if electric and make sure that you have free air flow from exhaust vent
4helpful
My DLE2514W LG dryer keeps running with 6 Min. Left
There is a humidity sensor (Hence the words Sensor Dry) inside the machine which trips out when it sees a lack of moisture in the air going past it.
It is not adjustable without special equipment
That sensor has failed and will need replaceing
1helpful
2answers
My new maytag centennial electric keeps tripping
Hi Matt
I'm not sure that swapping out the breakers to higher rated ones will give you a solution so I'll throw in 2 cents to see if my advice holds true. Let's start by asking this. Is the appliance "rated" at 220 volts at 30 amps per leg. I assume this from your post as to what it has been rated. Next - How long is the "run" of wire from the junction box to the outlet where the appliance plugs in? This usually does not matter in most households but if the run is of significant length it may need a larger gage wire to support the current draw of the appliance. Lastly, and perhaps most importantly, are the lugs and wire connectors tight at the outlet, the plug, and the breaker box. A loose connection will ramp up the current fast. This is assuming the first two items were met. Tell me if any of this helps and we'll work it out from there.
Thanks.
Len
2answers
Hotpoint FDW60 Flashing lights 3 and 5
Is it possible that water has gotten inside the controls that could have caused the flashing lights? Kind of like spilling water on a calculator, everything seems to go haywire.
Top Dryers Experts
john h
