In the USA Contact customerservice.ce @ hal.hitachi.com
or order here https://hitachi.camcorderi.com/hitachi-camcorder-a-v-cable.html
SOURCE: How do I upload my raw-video from my Hitachi BX35A mini DVD-RW camcorder to my pc for editing?
Hi
I think I had a similar problem with my new Panasonic DVD camcorder. Even though I had finalised the RAM disc the PC could not read the disc but could see it. I tried drag & drop into a new folder on my PC. I then renamed the video files by changing the ending to .VOB.
I could then open & play these files in Power DVD. Using software downloaded from the internet I converted the VOB files into AVI and could then use PINNACLE to edit them into a holiday movie/DVD. Some software will enable editing/reading of VOB fileswithout converting to AVI but as I am familiar with PINNACLE I just stick with what I know! Bit laborious but it worked for me.
I still prefer my mini dv camcorder - firewire works perfectly & direct into PINNACLE software for editring..
Hope it works for you
Dave
SOURCE: CABLES
you need a RCA Connectors to plug your camcorder to your tv. its like 2 jacks at one end and a jack (just like the connector of the headphone and earphone) at the other end. hope that helps
CHARCOIS
SOURCE: Hitachi Camcorder Finalizing
I struggled with the same problem. The disc cannot be finalized without the power adapter that connects the charger to the camera. After much research, I finally found the solution. Do a Google search for Hitachi part # EV11012. Panasonic uses the same part number for the same part but for some reason the Panasonic part is usually $50 more expensive than the identical Hitachi part. Either brand EV11012 part is the magical part you need and I found my brand new Hitachi OEM part online for $20. Prior to be finding the correct part number, merely searching the internet for an AC adapter for the BX35a only yielded results for all the crappy Chinese aftermarket battery chargers.
SOURCE: hitachi dvd cam bx35a dvd door wont open
I have yet to figure out this same issue 4 years later and still won't open. Can't finalize any of my DVD discs so I can't even watch the DVDs I was able to record before the door jammed shut. Someone told me wolf camera was a great repair shop. I've just not had the time. Anyone with any knowledge of this I'm at yahoo and email is... Rileygurlzmom
