Question about Whirlpool Washing Machines
Have a Kohler whirlpool tub. 1992-94 don't know model. After Power outage the pump turns on when power is restored. Unit works otherwise. Control is wall mounted. Has Start/Stop button, Set Time Button and LED type indicator for amount of time. Circuit board has 60257 Stamped on it and G5180 written on it. 4 wires go to the circuit board connector: Black, Yellow, Red, Green
6ya staff
SOURCE:
Anonymous
SOURCE: Power Surge damage. Suggestions on which part to replace.
I would start looking at the power supply, it's usually a separate board where the a/c line plugs into. In many cases i have seen that the problem you described is from a damaged power supply, sounds like something is shorting causing the power supply to continuously come on and off. I would first check the capictors to see if any of them have blown, usually cylinder looking and sometimes you'll see an X or a K at the top of the cylinder, if it's blown then the top will be bulging out instead of being flat. If all those look good then there is probably a short somewhere else like in one of the transistors, if so you'd be best to just find another power supply board to replace.
Posted on Nov 09, 2007
Anonymous
  • 40 Answers
SOURCE: I have a Carrier 38tra048340
Blank screen sounds like a fried thermosat. Abrupt outages can affect certain types of thermostats. Make a jumper wire and jump across R and G. See if you get any action from anywhere. If a fan or compressor kicks in you know you have a burned out thermosat...
Posted on Jun 23, 2008
pgh_pa_guy
  • 2992 Answers
SOURCE: T6410 EMACHINE TRYING TO CONNECT START BUTTON
The motherboard in your computer is an MSI MS-7145, which is also called RS480M. You can download a copy of the manual here. The front panel connections are on page 2-20.
Looking at the header JFP1, pins 1 through 9 (odd numbers) are the front row, pins 2 through 10 are the back. Pin 10 is the missing pin. The power switch connects to pins 6 and 8. The power LED connects to pins 2 and 4. The HDD LED connects to pins 1 and 3. The reset button, if used, connects to pins 5 and 7.
Posted on May 13, 2009
wildwest1959
  • 25 Answers
SOURCE: Whirlpool wall oven stopped working after power outage
Ouch...sounds like the control module is blown. Thats the electronic timer. I've known this happen on several occasions. Bad luck!
Posted on Jun 25, 2009
Anonymous
SOURCE: Wires came loose of control unit from circuit
Rotate the iTrip AutoPilot FM Transmitter controller so that its buttons are facing up and its data cable is on the left side. The data cable wires attach to a row of contact points along the left side of the circuit board as follows (from top to bottom):
1 = Purple
2 = White
3 = Blue
4 = Red
5 = Black
6 = Brown
7 = Green
8 = Yellow
9 = <unused>
Posted on Apr 22, 2010
New homeowner. Kohler airjet Master tub after hitting power button only stays on for about 20 seconds. Home inspection working fine I believe
put your ear to the side of the tub and momentarily turn on the jet pump, if you hear a humming sound then you need to replace the pump motor capacitor.
Jan 07, 2016 | Home
Jet streams whirpool not working after heavy lightining storm. lights in the tub do work, but do not turn off Unit about 6 years old model TO3C 1348
you have been hit by power surge. most likely the problem is in the control box that controls the pump. Need to call local plumber or service company to take a look at the system.
Verify that all circuit breakers are on and stay on after being reset before calling service tech.
US Parts Center
Aug 21, 2011 | Kohler Home
My Oaisis II hot tub stays at 103 and now it's dropped down to 68 degrees for the past 3 days? Could there be a problem with my heater element? Or is there a sequence of resetting the temp buttons on top...
Information on the care of your product and troubleshooting is available here:
http://www.oasisleisure.ca/customer_care/SpaCare.html
Did you have a recent power outage? It is necessary to reset the temperature after a power outage.
Check the temperature setting on your hot tub; if it has defaulted do to a power outage reset to the desired temperature. If it is still set at your desired setting and is operating at 68 degrees then there is a problem that is preventing the tub from reaching the set temperature.
Some possible causes and actions are:
Pull filter (see if light comes on) / Replace filter
Knife valves not fully open / Open knife valves
Pressure switch cut of calibration / Adjust pressure switch
Faulty Pressure Switch / Replace pressure switch
Air leak, check pump suction line / Tighten pump union
Heating element corroded / Replace element
Faulty control panel / Replace panel
Find the Manual for you specifc model for more explansyion on Troubeshootig.
Feb 06, 2011 | Home
My kholer jetted jacuzzi tub will not come on or do anything...just bought this home and to the best of my knowledge worked prior to.
make sure there is power to the pump. Some of their model require you to be in the tub full of water before the pump will turn on.
Dec 16, 2010 | Kohler Home
Kohler bath whirlpool turns off after 1 second
When you say turns off, is it tripping the safety circuit?
Dec 26, 2009 | Dream Maker Spas Dream Maker Ez Spa Hot...
Motor not working at all. Won't even go on
a good electrican will check for power but may not be able to test a printed control board. Maybe simpler to get a spa repairman
Aug 12, 2009 | Kohler 1014-H2-96 Portrait 5' Whirlpool...
Kohler Whirlpool tub motor wont turn on
We had the same thing happen to our Aker brand whirlpool tub.  The fix was a replacement timer/control piece which is connected by two wires to the pump behind the tub (access wall) and plugged into the outlet; however, this cost $150 for the part and $85 for the service call (all he did was take the part out and ship me the replacement part which was easy to do).  Problem I have now is that the motor won't shut off unless I unplug it.  I am waiting for a call back from the repairman who sent me the part.
Jan 11, 2009 | Kohler 1209-LA-0 Hourglass Whirlpool with...
Kohler whirpool tub will not turn on
Here is the manual for the tub. The switch is an air switch with tube. You have to make sure the tube has no holes in it or replace it if you can. look on the manual it will help you out.
http://www.us.kohler.com/onlinecatalog/pdf/1010564_5.pdf
Dec 14, 2008 | Kohler 1263-96 Folio 5.5' Drop In...
How to identify make and model of old whirlpool tub?
This is a problem common to all whirlpool/air jet style tubs. The pumps become air locked due to the water evaporating from lack of use. All tubs need, and have, SOME means of priming the pump, this is most likely what the problem was, originally, for you. This time in particular you found it to be electrical in nature but for future reference, for you and all who have these style of tubs, I am putting this out there. Some where on the tub, usually along the top edge of the tub is a vent knob that controls the amount of air that the pump is allowed to mix with the water for the jets, usually by closing this valve all the way (tub needs to be full of water of course) and running the pump for a minute or 2, you should be able to get the pump pumping water again, if not you may need to do something else with your particular set-up to get it purged of air, the pumps in jacuzzi tubs are designed to pump water, not air, so if the motor is running but you get no jet action, your most likely air locked and need to prime pump/purge air.
Sep 22, 2008 | Home
Washing Machines Logo
51 people viewed this question
Marvin
Marvin
Gerry Harvey
Gerry Harvey
jimorris77
