It sounds like your color wheel is going out. Here is the part#. If you do not feel cofortable with this type of repair, please have a servicer do it for you. Good luck to you.
Your Mitsubishi television is powered in part by a 180 watt lampthat illuminates your TV's vivid colors. ... The first time they delivered my TV it was broken. ... I just barely got myreplacement bulb in today and it still only blinks orange light. .....I was watching my mitsubishi 73 3d model wd-73740 and ...
6 mins ago - after replacing bulb on WD-82738 still not working bulb went out and burning smell. Replace the bulb, turned it in - Mitsubishi WD82738 82 ...
Jan 12, 2015 - I have a Mitsubishi WD-82738 with the blinking green light of death as I have seen it called. ... Sounds like you replaced the parts, and it still is not working.... It would not work for us if we did it after the blinking. ... overnights. an ive already t akeing out the bat Forum; blinking green light changed bulb help!
See page 6 (this is a display & basic explanation of your transmitter) of the owners manual http://mitsubishi-tv.com/asset/file/basic_owners_guide/738-838_BIB_v3.pdf
there is a format button on you remote transmitter. If you have other format issues it is probably your source & not the TV. You may have to change the source format in which case you will need that mfr. operating manual.
I hate being the bearer of bad news, had the same problem, and I found out that the problem with DLP is that after so long, nothing that you do will fix it. A TV repairman offered me $100 for my set and I took it, that was 2 years ago and it still goes through bulbs and ballast several times a year. Now when i see him he always says I never should have taken that TV. It never plays long enough to sell it.
On a liter note: 4k si approaching $1000 now, that's the way to go.
Power supply regulator board fault. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/ It will be best to replace the power supply regulator board as card basis.
These blinks are fault indication, and known as blinking codes. From the number of blinks occur at one time switch ON; you can get an idea about the faulty circuit stage inside the TV. This will make repair easy. For more information, check the link http://electronicshelponline.blogspot.com/ Blinking code detail, and fault finding procedure to many brand TVs are given. Pull up older posts.
