Question about Lands Phones
How do I delete the cordless incoming calls ? Frank
6ya staff
SOURCE:
Anonymous
  • 81 Answers
SOURCE: no ringer for incoming call
I have seen this issue before and panasonic knows about it. I would contact them directly.
Posted on Mar 30, 2008
Ajkill
Anand Kumar
  • 2035 Answers
SOURCE: uniden cordless dct646-4 phone
Try to set it factory mode and use if this fails then the ringer speaker is defective ,if its within warranty get it replaced or get it serviced it will fix the issue .
or use this link to download the owner's manual.
http://www.uniden.com/search/searchresults.cfm?searchstuff=dct646&image2.x=10&image2.y=12
good luck............
Posted on May 28, 2008
Anonymous
SOURCE: model 28112ee2-4 dect 6.0
SOLUTION: My handsets stopped ringing after power was stopped to the main base, too. I put one on the main base and that one started working but the others still didn't work. So I put the other phones on the main base while I called from my cell and let it ring. The other phones started to ring and work again.
Posted on Oct 18, 2008
Joed911
JDTec
  • 4338 Answers
SOURCE: deletion of incoming calls
I believe you have to delete the messages individually. Here is the online iPhone user's guide:
http://www.scribd.com/doc/2527212/iPhone-User-Guide
Click on this link or copy and paste the complete link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Posted on Feb 01, 2009
Anonymous
  • 39 Answers
SOURCE: uniden 5.8Ghz phone.
You need to reset the main base unit. Unplug the power from the back of the base. While the power is disconnected, press and hold the delete key while reconnecting the power. Wait for a long beep tone. When the display shows 88 or P, press play button one time. If you have a phone without an answering machine, disconnect the power from the back of the base, press and hold find hs button while reconnecting power.
Posted on Mar 17, 2009
Delete incoming call log?
1 Press Cid when phone on standby
2 Press Menu/Select
3 Select DELETE ALL
4 When phone asks you to confirm select YES
Apr 25, 2014 | Uniden DECT 6.0 Cordless Phone
I have a 2 handset GE cordless 25932EE2. Both handsets work great individually, BUT when we answer an incoming call with one phone, we can't use both handsets at the same time (for the same call). In...
The problem may be due to both your handsets operating on the same channel. To fix, try pressing and releasing the "chan/delete" button on one of the headsets. This will move it to the next available channel.
Mar 08, 2011 | GE 25932 Cordless Phone
Can you help me delete an incoming call to my cordless phone?
Since you declined to specify the model of your VTech DECT 6.0 system, I can only suggest you enter it into the search box here to download the manual.
Oct 10, 2009 | Vtech DECT 6.0 Cordless Phone with Digital...
How to erase incoming and outgoing calls in
go to resent calls and delete the incoming and outgoing calls
Jul 17, 2009 | Panasonic KX-TGA101S Cordless Handset
GE 5.8 ghz cordless phone
the menu will take you to registering the hand sets to the base unit
by deleting incoming calls you have disconnected from the line
follow the instructions in the user manual to get reconnected
if you do not have the user manual , go google and type in --user manual for ge ( model ) cordless phone --and down load the pdf version
May 25, 2017 | GE 27957GE1 Phone
Answering machine wont pick up it just cuts off incoming call leaving line busy
just set the amount of rings higher on the back of the phone and make sure all you old messages are deleted and also make sure its not set to do not disturb
Mar 28, 2008 | Uniden Cordless Phone
Uniden 5.8Ghz phone.
Jan 20, 2008 | Uniden Cordless Phone
Lands Phones Logo
26 people viewed this question
Top Lands Phones Experts
Ekse
Marvin
Marvin
Are you a Lands Phone Expert? Answer questions, earn points and help others
