Question about Bosch Washing Machines
Where can i buy siemens bosch PCB circuits in Mumbai?
What does error code f67 on a siemens wash machine mean?
I have a Siemens WM16S772DN washing machine and encountered the error code "F:67" followed by repeated beeps. (Note: Siemens and Bosch are related companies). I called Siemens and they said the code means "Fatal error" or program error. The service technician was called, and he replaced the electronic board and reprogrammed it.
Apr 18, 2011 | Bosch Washing Machines
We have a Siemens SL84A305UC Dishwasher and it just keeps running and running. Someone suggested that it may be the control panel. Does anyone have any other suggestions or experience? Thanks!
Hello and welcome to Fixya. The assesment of the control is likely accurate. Siemen is made by B/S/H/ ( bosch/ thermador/ siemen/ gaggenau) and there is plenty of president for this issue. Likely if you select just a rinse cycle it will complete fine since the rinse cycle doesn't call for heat from the element/control. sooo... Based on your description I'd say the issue IS indeed with the control. As I said B/S/H/ has had a history of this exact problem I'm about to lay out for you and this is the first thing I'd be looking for if called out to service the unit with the symptoms you've described. ( unless you requested a resolder option...see below re: my opinion on this ) I digress, As I've alluded to the issue is within the electronic timer/control, specifically the heater relay solder joint. ( a faulty flow switch, ntc or heater can also cause this, but not very probable ). My first suggestion would be calling in an authorized bosch/siemen servicer if that is an option for you and your budget however, If you cannot afford that option or simply feel you want to attempt and are capable of checking this on your own, there`s a way to visually inspect the control yourself. It will require you to remove the control from the unit and then remove the control from it`s plastic housing and look for a burnt solder contact on the printed circuit board. This will be one of the pins from the heater relay, hence the unit sit`s and takes forever to finish because it can`t heat to advance or unless the 2 buttons for "cancel" are pressed. **My Opinion - if you or someone you know is proficient at soldering, a lot of times it can be remedied by simply repairing the solder...but it has to be done well...half assed will not last, although Bosch recommend`s replacing the control and I don`t pretend to speak on there behalf nor do I profess to know better. This is just my experience (it work`s) and my opinion (why buy new if one can repair ?)** **Please disconnect the power before attempting any service to the dishwasher. If you do not feel comfortable attempting this service, call a local pro, preferably one familiar with Bosch/Thermador/Siemen/Gaggenau, to service your machine.** Hope this answer`s your question, let me know if I can assist you further. Thank`s for visiting "fixya" for your repair inquiries. Please take a moment and rate this solution to it's helpfulness. Good luck. macmarkus :)
May 08, 2010 | Siemens 24 in. SL84A305UC Built-in...
Control panel looks ok but dryer wont start
Sounds like an electronic problem on the timer circuit board.
Aug 11, 2009 | Siemens WT79020EU Electric Dryer
Where can you purchase Siemens parts in the USA? We've just begun our search for a drain pump for our WFXD5200UC UltraSense Washer. Thanks
www.apdepot.com
they are very reasonably priced. If you don't find the part on their website, call them.
I just purchased that same part (drain pump assembly) for about $ 63.
Now I have to find out how to access it to replace it!!
May 16, 2009 | Siemens WFXD5200UC Front Load Washer
Washing Machines Logo
Top Bosch Washing Machines Experts
Marvin
Marvin
jimorris77
Dw Wooten
Dw Wooten
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
