Yes you can switch your phone off 1st,then power on,but this time hold the menu/home button down with the vol up button.keep your menu and vol. up button pressed..only leave go of ur power on button once power on starts..keep the other 2 buttons pressed in about 20-60secs you will see an green android man..leave all buttons go..after bout 30secs more.you will see a menu..this is the RECOVERY menu..CAREFUL...choose reset cache 1st when that completes choose reset phone..user data will all be deleted..after that completes choose restart phone..INSTRUCTIONS TO USE..select option using vol up and down..select using power button.
PLEASE BARE IN MIND ..this will delete all ur photos. Phone numbers etc etc ..so make a back up 1st via goggle..and remember your google password..because phone will boot up as if it was just unboxed..be AWARE phone may ask you to sign in google..if you not signed out on your phone 1st
Yes, you have to restart your phone in recovery mode. From there you can reset your phone,
SOURCE: how do i erase all contacts from my motorola i880 phone?
My contacts are full on my Motorola i880 cellphone
How do I delete to create more space?
SOURCE: My Nextel i880 says enter special code what should I do
Sound as though maybe you're trying to use a "boost" sim card on a Nextel phone. The phone has to be unlocked in order for that to work.
SOURCE: Need Boost SIM card to work in Nextel Motorola Buzz+ ic602 phone.
I called Boost support about the same issue and I was told that that particular phone and any other Ic series phone by motorola will not work with Boost Mobile. There was also a few other phones that will not work. Try calling thier support line and requesting the list of phones that won't work. Good luck.
SOURCE: transfer contacts from a sim card onto cell phone
Go to contact list and select the contact.press option button then press copy option then press copy to phone.
