SOURCE: change LCD language to English on Brother MFC-3240C
Gud Day!
Power on your printer. Press the menu of your printer then sect the arrow down or up to select the language menu. press ok if u have seen language then go to option select from german to english.
Please rate the solution after you have tried it so that I can assess you more on this problem.
Jonags
SOURCE: ! Unable to print 36
here is the solution according to brothers website
http://www.brother-usa.com/FAQs/Solution.aspx?FAQID=100000012648&Sympt=How+do+I+clear+error+message+Print+Unable+36%3f&Model=1208&ProductGroup=1&ProductID=HL4070CDW
SOURCE: Brother MFC-465CN says 'Unable to Print 5A'
Hi there
Solution:
· Machine off
· Switch on the machine while holding down the “menu”button until all the leds are flashing on/off. Now you are in “maintenance” mode.
· Press 80
· Press the “mono start” button several times until you see “purge: xxxx”
· Press “2783” in order to reset the purge counter. You will see: “purge:0000”
· Press the "stop" button.
· Press “99” to exit the maintenance mode.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
SOURCE: I have a Planar 1910(Black)
It has white screen becuase it may not be getting the 5vdc from the logic board to the T-CON board or the board has blown fuse.
Please see http://s807.photobucket.com/albums/yy352/budm/LCD%20panel/
Also look to see if power supply/logic bd had any bad caps also.
Testimonial: "Thanks! It was the TCON that was the problem. I had to reconnect it, it was not inserted all the way in."
SOURCE: Brother MFC 8860: Display reads
I have exactly the same problem with my Brother 1250 mono laser printer.
Any solution yet?
