To remove the fraction display on a Porpo YH-2000 calculator, you can follow these steps:
Press the "Mode" button to access the calculator's settings.
Use the arrow keys to navigate to the "Fraction" or "Frac" setting.
Change the setting from "On" to "Off". This will remove the fraction display from the calculator's screen.
Press the "Mode" button again to save the changes and exit the settings menu.
If these steps do not work, it's possible that your calculator model is different or that it has a different method of changing the fraction display. In this case, you may want to consult the manual or manufacturer's website for more information.
Quite simple with your PORPO calculator, you might wanna first press the reset button which is usually at the back of the calculator with a small pin or pen, then you're set to go.
(1) Press the "MODE + 2" This brings you to the standard deviation mode on the calculator
(2) To input the numbers you wish to work on, say (1,2,3,4,5) Press "1" then press "DATA" button, this will display "n=1" meaning you have imputed 1; Subsequently, press "2" and hit "DATA" again meaning you've imputed 2; Repeat this cycle till you've imputed 1,2,3,4,5 successfully
(3) Now hit "SHIFT + 2" or "SHIFT + 3" (as the case may apply) for standard deviation
(4) Could also find mean, summation etc by hitting "Shift + (whichever number is applicable as shown on the calculator button)"
Im fijabi taiwo from nigeria [email protected] Turn to the back of calculator you will see where reset is written,use something tiny to press it by inserting it
