SOURCE: Magic chef stove
If the oven is working but the control does not light up then you will have to replace the control. If the oven doesn't work then will have to check and see if you have power to the control. If power is there then the control is bad.
SOURCE: need to replace lost power cord fpr back pack bantam 181100
the factory power transformer is 5V 1 A model TRX-022A input is AC100-240V 50/60 Hz 0.15A output DC5V 1A
SOURCE: magic chef refrig model # MCBR1000W defrost thermostat
RepairClinic.com is a fantastic online site for ordering appliance parts.
SOURCE: ovens not lighting magic chef
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or Oven not Heating
Oven Problems Replacing the Igniter
heatman101
wwt
The reason it is a 120/240 is because the clock and the Controls will run on 120.
The stove has 1 cord, which is a 240 cord, The stove itself Will use the 240 and take 120 from the same cord.
240 is just 2 power wires that have 120 each. AC means Alternating current, which means the power goes back-and-forth in the same wire. The two power wires (which alternate in opposite directions) work together to give continuous power instead of alternating. I hope this helps
