Caleb Jackson Posted on Oct 28, 2019
JBL charge 4 stuck in demoo mode. How do I fix this. Also it can't turn on . when charging the power buttons turns on white and dosen't flash oor does anything.
prashant naidu
Level 1:
Habit-Forming:
Welcome Back:
Visited the website for 2 consecutive days.
  • Contributor 9 Answers
  • Posted on Nov 24, 2019
prashant naidu
Contributor
Level 1:
Habit-Forming:
Welcome Back:
Answers
9
Questions
0
Helped
5457
Points
34
Try doing default factory settings.
Step 1. Press the "Power" button located on the top center part of your JBL Charge 4 Bluetooth speaker. The speaker will be powered on when the LED backlight under the Power button is lit.
Step 2. Hold down the "Bluetooth" and "Volume Up" buttons at the same time for roughly three seconds. The Volume Up button looks like a plus sign. Additionally, it's important to hold down the "Bluetooth" button in the center of the device next to the Power button, as it's easier to hold down. After three seconds, the LED ring around the Power and Bluetooth buttons will briefly light up before the JBL Charge 4 powers down.
Step 3. Press the "Power" button again to turn the JBL Charge 4 Bluetooth speaker back on. The Charge 4 will instantly turn on in Discovery mode, with the Bluetooth LED blinking on and off, and the speaker making a pinging sound. This confirms that you've successfully reset your JBL Charge 4 to its default factory settings. You'll need to pair or re-pair any devices you want to play audio through the JBL Charge 4 speakers with the device.
5 Related Answers
Anonymous
  • Posted on Dec 11, 2008
SOURCE: HP NX9600 wont power up.
The Compaq NX 9600 is rather a complicated and somewhat notorious problem child. One of HP's better ideas, and a good one when it is working.
Disconnect Power adapter from PC
Remove Battery
Hold down power on button for 30 seconds
Remove both memory modules, Stot1 and Slot2.
Re-install battery
Re-connect power adapter
Attempt to reboot.
If nothing happens the book says replace the motherboard which is very pricey.
email me @ [email protected] and give me and update as I don't visit this site often.
Alan
Anonymous
  • Posted on Jul 04, 2009
SOURCE: Screen flashing
I had the same problem. You will need to put it in the car cradle and plug it into the car charger. It will come on immediately.
Anonymous
  • 3422 Answers
  • Posted on Aug 02, 2009
SOURCE: my K610i won't turn on. Red light flashes n won't charge.
HI,
That indicates a problem with the battery.Try a reset first.
Connect the phone to the power adapter and then press and hold the power button for more then 1 min.If it still doesn't turn on then remove the battery and sim from the back and then insert the sim back again and hold the power key for more then a min.Make sure you don't insert the battery now.Let me know the result.
Thank you
Anonymous
  • 174 Answers
  • Posted on Apr 04, 2010
SOURCE: nokia 1661 slight water damage - test mode
you can take the battery and the back off the device and place in completely submerged in a bag of white rice and leave it in there for 1 to 2 days this will help absorb the moisture, this should fix it if the water did not damage the circut boards if the water damaged the circut boards then the device is fried
Anonymous
  • 154 Answers
  • Posted on Apr 27, 2010
SOURCE: I unpluged my phone from being charged and when I
Only way to clear the error is to remove the battery.
I hope this answers your question.
Thank you for visiting FixYa for your solutions.
Susan
PS - Please be sure to leave positive feedback :0)
JBL charge 4 only powers on if plugged into wall..
It sounds like the internal battery has failed. Try and claim on the warranty or ask for a repair.
JBL Support - Returns & Warranty
JBL https://ca.jbl.com > support-returns-and-warranty
If you believe your product is malfunctioning during the warranty period, we can help!
Warranty
JBL https://ca.jbl.com > warranty
Unless a different warranty period is stated in the Warranty Card provided with your JBL product, JBL warrants for a period of 1 year (5 years for any non- ...
Troubleshooting help
https://www.ifixit.com/Wiki/JBL_Charge_4_Troubleshooting
JBL Charge 4 TroubleshootingiFixithttps://www.ifixit.com > Wiki > JBL_Charge_4_Troub...Make sure the charging light on the base of the device is blinking. If it is fully charged and still not turning on, the power button may be worn out or broken. ā€ŽThe Speaker Will Not Power... Ā· ā€ŽThe Device Won't Connect to.....
2helpful
2answers
I've owned my LBT/JBL Vibe earbuds for a while and both were working yesterday and charging fine now today only one is working and the other one is charged but it will not work?
looks like holding for 5 seconds enables manual pairing of each earbud
https://manuals.plus/jbl/vibe-300tws-true-wireless-earbuds-manual#manual_setup
My JBL e45bt wireless headphones won't turn on. I've tried charging them overnight, but i doesn't help at all. How do I get this fixed?
If your JBL E45BT wireless headphones will not turn on, there could be a problem with the battery or the charging system. Here are a few things you can try to fix the problem:
  1. Make sure that the headphones are charged. If the battery is completely drained, the headphones will not turn on. Try charging the headphones for at least 2 hours to see if this resolves the issue.
  2. Check the charging cable and port to make sure they are working properly. Make sure the cable is securely plugged into the headphones and the power source, and that the port is free of debris.
  3. Try a different charging cable or power source to see if the problem is with the cable or the power source.
  4. If the problem persists after trying these steps, it is possible that there is a problem with the battery or the charging system. In this case, you may need to have the headphones inspected by a technician to determine the cause of the issue.
If you are not comfortable troubleshooting the problem yourself, it is recommended that you contact JBL customer service for assistance. They may be able to provide further guidance or offer repair options.
Jbl Pulse 2 stuck in Demo mode
Press and hold the * button for 2 seconds which should turn off the flashing lights.
Stuck CD in JBL 4 disc CD Changer / Navigation
before you press the cd on button keep holding the eject button while you press power on, I know this works for computers etc.
3helpful
Any way to Factory Reset a JBL Charge 2 ?
Yes, follow this sequence:
1. Turn the device on
2. Press the call (phone icon) and the volume up (+) button at the same time and keep them pressed. After a few seconds the speaker will shut down.
3. Release the buttons.
4. Turn the speaker back on. It will automatically enter into search mode... And there you are, memory wiped up.
Good luck.
1helpful
Help pairing jbl charge
Put JBL Charge in pairing mode: turn on Charge. Hold down power button till it flashes red and blue. You're in pairing mode. Go to your device and find Charge and pair up. Done!
Top JBL Audio Players & Recorders Experts
 Grubhead
Grubhead
Bob Kirkwood
ADMIN Andrew
ADMIN Andrew
Are you a JBL Audio Player and Recorder Expert? Answer questions, earn points and help others
