SOURCE: reset transfer belt samsung clp-300
Unfortunately you cannot there is a resistor on the unit that when you replace it it blows resetting the transfer counter.
Sorry
J
SOURCE: Samsung 600N transfer belt
I fought the "replace transfer belt" message for quite awhile. Then I finally realized I was trying to close the toner cartridge door BEFORE I closed the lid above it. (The printer was close to a wall so I couldn't see the "open and close in this sequence" signs on the cartridge door.) Once I closed them in the proper order, I stopped seeing that message. Janet
SOURCE: Transfer Belt vs Transfer Roller
Its a bogus message. Simply open and close the front cover of the machine. It resets it and the message disappears.
SOURCE: color ink on transfer belt
I posted the problem on 4/6/09 about my HP Laserjet 2600n with the black line from top to bottom on all pages. The issues ended up being with one of the toner cartridges. I replaced them all - and the line went away! I will need to go back now and find out which one it was, and then I'll toss that one, and I will keep / reuse the others.
SOURCE: Samsung CLP-300N was asking to replace transfer
open the top cover press and hold the main button wait for the 3 lights to go up, release and cover
Your printer monitors the life of your transfer belt. When the transfer belt reaches the end of its
life, the printer displays
80 Belt Exhausted. This message indicates it is time for you to
replace the transfer belt. For best print quality, make sure you replace the transfer belt when
80 Belt Life Warning.
Press
Go to clear the message. The Supplies message appears on the second line of the
display to remind you that supplies need attention. You can open the Supplies Menu to see
80 Belt Exhausted
or 80 Belt Life Warning messages.
The printer continues to display the
Supplies message until you replace the transfer belt. To
replace the transfer belt, use the following steps or the instruction sheet supplied with the
transfer belt.
Checking replaceables
If you experience frequent paper jams or printing problems, check the
number of pages the machine has printed or scanned. Replace the
corresponding parts, if necessary.
1. Press Menu until System Setup appears on the bottom line of the
display and press OK.
2. Press the left/right arrow until Maintenance appears and press OK.
3. Press the left/right arrow until Supplies Life appears and press OK.
4. Press the left/right arrow until the item you want appears and press OK.
• Supplies Info: Prints the supply information page.
• Total: Displays the total number of pages printed.
• ADF Scan: Displays the number of pages scanned using the ADF.
• Platen Scan: Displays the number of pages scanned using the
scanner glass.
• Imaging Unit, Transfer Belt, Fuser, TransferRoller, Tray1
Roller: displays the number of pages printed each item.
5. If you selected to print a supply information page, press OK to confirm.
6. Press Stop/Clear to return to ready mode.
when you reach the imaging unit reset it then try, it should work then
