SOURCE: Microwave blew up after cooking an egg
Yes the internal fuse will have blown. I would also think the door latch switches and monitor switch will also need re adjustment
SOURCE: microwave works for 30 seconds and then turns off
The first thing to try is a "hard reset". Unplug it from the power line for a few minutes, plug it back in, set the clock, then try again.
Let us know if the hard reset doesn't fix it.
We're happy to help and we appreciate your thoughtful rating of our answer.
SOURCE: LG ms-304ez microwave
I would suspect the fuse or the thermostat.
The fuse should be located on a filter board near the back of the unit where the cord comes in.
The thermostat should be located on the left rear corner of the chassis above the cooking cavity.
We have two service manuals for this type of model and have uploaded them to our site here and here to help you.
You will need the free Acrobat Reader to view or print them in case you don't have it already.
Since these are not exactly the same models as yours, the part number for the thermostat may not be the same. You should verify them with the distributor.
To order Goldstar / L.G. parts, visit Vance Baldwin Electronics.
Formore Goldstar / LG / L.G. help, call 1-800-243-0000 (M-F, 7am-8pm CT, Sat8-5 CT) and choose the appropriate prompt from the menu or visit here.
L.G. / Goldstar owner's manuals can be downloaded here.
SOURCE: Have the Nordicware Egg Cooker
Welcome to FixYa! If you are happy with my solution and are able to get what you need, I'd appreciate a rating so that I can continue to improve my service (and make my boss happy). Now to your issue.
Nordicware does not publish their manuals so I am providing you with a number where you can get a users guide mailed to you free of charge.
Call their consumer services department at 1-877-466-7342 8:00am to 4:00 pm CST
and we will be happy to send you the directions in the mail.
I hope this solution helps you enjoy your egg cooker for years to come and thanks for using FixYa!
SOURCE: my swan microwave just stopped
Hi, I believe you have done your microwave in. That was not a good thing to do. In all hand books it say, do not put a raw egg in it's shell in the microwave or it will explode. You will have to replace the wave gun (magnetron). Depending how much damage you did there maybe more to replace.
