SOURCE: I have an Equity Weather
The wireless unit that transmits to the indoor unit is weather resistant, but not immersible. Even so, try to shield the transmitter from the sun and rain, if possible. When positioning the transmitter, keep in mind that direct sunlight may cause false readings and mounting it on heat-retaining materials (like brick) will show a higher temperature, even after sunset. Avoid mounting it anywhere near things that give off heat (air conditioner units, dark exterior walls, etc.).
LaCrosse has not yet uploaded the manual for this, but you may check later at:
equitybylacrosse.com/31215
Good luck from Detroit, MI.
Testimonial: "Thanks the information given was very helpful"
SOURCE: Sharp Weather Station Model SPC344 The outside
After inserting the batteries, DO NOT set the time until the OUTSIDE temperature registers. That's the trick.
Its possible the radiator is not cooling enough to handle the engine and trans. Depending on where the aux cooler is for the trans, there may not be enough air flow thru the radiator. With the condenser in front of the radiator the ac produces extra heat the radiator has to overcome.
SOURCE: Lacrosse weather station model T85647
Either the sensor is defective or the receiver is, toss a coin.
