Cameras Logo
Trapper Rudisill Posted on Oct 27, 2019
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
No card keeps coming up an cam, can this be fixed?
Tony Parsons
Level 3:
  • Cameras Master 6,405 Answers
  • Posted on Oct 27, 2019
Tony Parsons
Cameras Master
Level 3:
Answers
6405
Questions
Helped
1650094
Points
20272
Check that the card is the correct capacity for your camera - look in the manual
Check engine light keeps coming on my 2002 Honda civic si. After MANY times at the same Machanic he keeps throwing codes to the car resets the light. After 30 miles or more it comes back on. Things he...
if its throwing a code for cam sensor but new sensor does not fix it given the fact of recently replacing the timing chain id say it sounds like the timing was not set correctly which is causing the cam sensor to receive abnormal readings throwing the check engine light on. pull cover and check timing mark placement against specifications
1helpful
Bmw z3 2.5i CODE p0340
The code is for the cam position sensor for the intake cam shaft.
You can clear the code and it may not come back. If it keeps coming back you might want to replace the sensor and double check the connections where it plugs in to the harness. Hopefully this will fix the problem.
Let us know if this helps, Robert
I am trying to access the SD card in my Hitachi DVD Cam and it keeps telling me "Card Error"
Try inserting a different card in your camera and if the problem persists, its a fault on your camera. A technician should fix it. On the other hand, if the new SD card is accessible, then the former card is corrupt. You should replace it.
When I try and take a picture the card lock comes up . How do I fix this?
Your memory card has been write protected.This can be fixed very easily.
  1. Turn off camera.
  2. Take out the memory card. (it's probably located near the battery. press down on it and release it. Then it will pop out.)
  3. Slide the small switch on the side of the card to the position marked with an unlocked padlock.
  4. Put card back in and turn on cam.
There. That's it. hope that helped.
Comes up with card error
Your memory card is either write protected or corrupted.
  • If it's write protected, it can be very easily fixed.
  1. Turn off cam.
  2. Take out the mem. card. (it's probably located near the battery. press down on it and release it. Then it will pop out.)
  • If that doesn't seem to be the problem, then it's likely that the memory card is corrupted. This is common with Flash memory that has been used extensively for a long time and this problem is likely not caused by any fault in the camera. You might not be able to access any pictures that were stored on your cam, but you can try using a data recovery software like Recuva if you want to recover pictures ( click name to download ). If you want to use the card again, You can try formatting it (differs from cam to cam, check instructions manual for specific instructions) If this doesn't work, You will have to buy a new card. Make sure you buy a good brand like Lexar or SanDisk.
1helpful
How do you transfer the photos to computer with out taking card out
Your camera will come with a cable, plug each end into ur PC and cam and turn it on and it shows up in "my computer" just like a pen drive! (and it acts like a pen drive too.)
But u have to remember these points, they're important.
  • If you edit any of the pictures using the PC, You can't view them with the cam again (happens even if u take the card out and use with a card reader).
  • If you keep it plugged in for a long time, the batteries will run low.
Anybody please help me!!! when I take picture my cam keep saying ''CARD LOCKED''.. how to fix this problem??? Please...
Just like old 1.44 drives, sd cards have locks on them. Take the card out of the camera. Look at the side of it and locate the slide. This lock and unlocks the card. This is a feature to prevent accidental erasure of the card.
Hope this helps.
Hi: My Sony camera keeps telling me to reinsert the Memory Stick which I do but keep getting the message. What is solution? Thanks!
Dear Friend,
Try Following...you will be Solved..
  • Insert your MMC in to a GOOD card reader and Check .. (any damage )
  • Insert in to CAM
  • If still same,Insert another MMC in to your Cam
  • Still same,Then Check your MMC jack(any Contacts damaged)
  • Then you have to Manual Repair your CAM
YOu are Done..
Is this Text Helped You .. Do Rate Me... YOu can Feel Free Contact me.. Thanks For Using FixYa
1helpful
The sreecn keep saying the memory card it protected
There is a lever on the SD card. Pls. change the position of the lever.
Make sure the SD card is compatible w. the cam. model.
Contact KODAK:
http://www.kodak.com/eknec/PageQuerier.jhtml?pq-path=14563&pq-locale=en_US&_requestid=3490
4helpful
2answers
Fuji s602z CF II card not initializing
I've bought a SanDisk ExtremeIII 4GB CFI card. Ofcourse, at the beginig nothing worked. Camera format command worked neither (initializing problem,...). I then formated my card through a car reader on fat16 and now everything works. Just make this command: format <volume>: /FS:FAT. After checking and formathing the card, you will be asked to go on by 64K size of cluster. say Yes.
Top Cameras Experts
ZJ Limited
ZJ Limited
ADMIN Andrew
ADMIN Andrew
Are you a Camera Expert? Answer questions, earn points and help others
