Ovens Logo
a
anne cole Posted on Oct 27, 2019
My electric oven has auto flashing. how do I turn auto off.
Juan Manuel
Level 1:
New Friend:
Problem Solver:
  • Contributor 5 Answers
  • Posted on Oct 29, 2019
Juan Manuel
Contributor
Level 1:
New Friend:
Problem Solver:
Answers
5
Questions
0
Helped
4555
Points
11
1 Related Answer
Anonymous
  • 4 Answers
  • Posted on Jan 23, 2010
SOURCE: GE electric oven JBP60
replace the "logic switch" attached to the oven locking mechanism. I had the same problem and it worked for me.
Dont know how to turn off the auto seting
Turn off the mains power. wait about thirty secs. turn back on, you should have either all 0's or 8's flashing. Looking at the clock buttons left to right. press the button fourth from left and the - or + to set the time (doesn't have to be the correct time, just not flashing 0 or 8's). Leave for second until the display is not flashing.You should be able to use the oven now. If not you may have a problem with the clock, this can happen if you have been using the top grill with the door open and the controls have gotten too hot. Neff ovens have no function where the door is left open during cooking or grilling.
5helpful
We had a power cut, now I can't get the oven to work the auto light is flashing but when I turn the knob for the oven it won't come on.
You need to reset the oven from auto to manual setting.
This is done by pressing 2 or more buttons on the timer at the same time to reset it, until you do this, the oven will not work
GE electric oven JBP60 ''Auto Selff Clean'' light flashes when oven is turned on and results in no heat. Broil element works
Dec 22, 2009 • GE Ovens
Display is flashing0.00 and auto. oven won't work
Try turning the oven circuit breaker off for a minute then back on. Reset the clock and see what happens.
36helpful
Baumatic Oven - Setting the Clock/timer after power has been off.
Hi, You press the second and third button in together, hold them in and use the + or - buttons to set the time.
Oven won't work after cleaning
Molly,
"Auto Clean" means that the control thinks the door is locked. If you can open the door, it's obviously not locked. You can try turning the power off at the breaker. Leave it off for 20 minutes or so. See if this resets the control. If not, the high temps in "auto clean" may have fried one of the monitor switches on the door latch.
Let us know what happens.
SG
Mar 26, 2009 • GE Ovens
1helpful
My magic chef oven will not heat in the oven or on the stove top after the electricity was shut off for a few hours. what could be the problem?
If it has a timer, make sure it is set to manual,and not flashing auto.
In the auto mode the oven will not work.
Plz rate this solutioin.
Thanks.
2helpful
HOTPOINT DOUBLE OVEN mODEL uy46 BOTTOM OVEN NOT WORKING CANNOT CL
While it is flashing auto ,you will not get the oven to heat up.
You must press the timer buttons in the correcf sequence to cancel auto.Refer to user hand book.
If you suceed with this, and the oven still does not get hot, then the element has probably failed.
Oven not heating but the fan is working and clock flashing auto
You need to rest the timer. to get it off auto,otherwise the oven will not work.
Refer to your instructions.
1helpful
Zanussi oven wont work. clock flashing 'auto'
you need to set clock before oven will work. do you still have instruction book as it will tell you there how to do it
Top Ovens Experts
ZJ Limited
ZJ Limited
john h
Are you an Oven Expert? Answer questions, earn points and help others
