Is the charging of the battery part of the camera or is it a separate charger? Meaning you remove the battery from the camera and install it into the charger to charge. Of course, if the charge is not full when both batteries have been on the charger, then the charger is at fault. Also, considering that you have also put a new battery on the same charger and the problem is still the same, then the charger is (again) at fault. You can try and send the charger to the retailer for inspection or, better still, take the whole camera and get it checked. Bad batteries or charger can cause more trouble to both the batteries or the camera.
Red light flashes rapidly when charging. It won't hold charge.
