Tasco Wide Angle and Rubber 2023 (10x50MM) Binocular Logo
Posted on Sep 18, 2009
Replacement parts for Tasco binoculars
I am looking for a viewing eye replacement part. It is the round piece that covers the lens you look through. It is the rubber piece that seals the area around your eye that you view through.
69pablos
Level 1:
New Friend:
  • Contributor 7 Answers
  • Posted on Mar 20, 2010
69pablos
Contributor
Level 1:
New Friend:
Answers
7
Questions
0
Helped
15904
Points
18
You'll need to measure your eyepiece in "mm". Also determine if your eyepiece has an outer ring the eyepiece will slip over. You can find eyecups/guards on Ebay. Search under Binocular Eyecup or Binocular Eye Guard. There are also eyecups under "rubber eyecups/rubber eyeguards" but alot of these are for Microscopes and may not fit. You will need to pay close attention to the mounting type and measurements.
1helpful
Hi, i dropped my binoculars and im having trouble finding replacment parts to repair them tasco 2012brz zip
Sadly, considering they are likely inexpensive, best thing is to replace them completely with a new binocular. The price to repair them could be better spent on a new or good used binocular.
If that isn't acceptable, you can Cory at [email protected] for a price for parts or repair. He comes HIGHLY recommended after I have received consistently high quality repairs on different pieces of optical equipment I've sent him.
Good Luck
Missing a bit
Ebay has them under telescope eyepiece catagory
How to hold binoculars properly
1. Remove the lens covers, if they are in place.
2. Set the diopter on the right barrel eyepiece. The function of this setting is to adjust between vision differences between your eyes if you are NOT wearing corrective lenses. Set to zero if you do have corrective lenses on (glasses or contacts). For proper diopter adjustment see this article: Binocular Selection Guide.
3. Most binoculars will hinge in the middle to allow for differences in the spacing between the eyes. Set the spacing to fit your eyes.
4. Adjust eye cups. Each eyepiece will have a means of maintaining the correct eye relief for the user. On quality binoculars the rim of the eyepiece will extend and retract as you twist the eyepiece rim. Move all the way in if you are wearing eyeglasses or adjust out if not wearing eyeglasses. You will know if they are set correctly when you look through the binoculars and check to be sure that the circular edge of the view should be sharp and not fuzzy. At this point we are not looking at any object in the view but rather the perimeter of the view. You may need to adjust the eye cups again to compensate. On lower cost binoculars the eyecup may only be a rubber lip that you either fold over (the "in" position) or out.
5 Raise binoculars to your eyes and use one finger to adjust the focus wheel on the center shaft between the two barrels, until the view is in sharp focus. If viewing for extended periods you may want to keep your elbows down near your side as this will increase comfort while viewing.
Final safety tip: Do not look at the sun through binoculars.
Many people enjoy observing nature with binoculars. Having them handy is key. Hunting, astronomy, marine use, and stadium sports are a few more activities where having a pair of binoculars can make a real impact to your experience.
Missing lens
This is going to be very difficult to replace. However you can try contacting this company to see if they can order the part? Tasco does not sell replacement parts directly to the public.
http://agenaastro.com/
I have a tasco 2x7x32mm which has fogged up, It is to have a lifetime warranty and am looking for information on getting it repaired?
Can you unscrew or detach the front lens? You should be able to do this.
Get some eyeglass Zeiss cleaning tissues from Wal Mart, and clean it, very gently. Brush it off first with a clean camel hair brush.
If it is fogged BETWEEN the lens then it must go back to Tasco.
This is a VERY small diameter telescope. The same size as a pair of 10x50mm binoculars. You would have a better view of the sky with the binoculars.
http://www.handgunrepairshop.com/tasco.htm Warranty service
Two rubber eye pieces for Tasco 6x.18x35 triple zoom binoculars
Link
Your binocular might be needing some repair or material replacement. Kindly refer to above link to contact Support Team of Nikon
Thank you.
Top Tasco Optics Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Ngoro
Are you a Tasco Optic Expert? Answer questions, earn points and help others
