Samsung HT-Q100 System Logo
Posted on Dec 13, 2017
HTX100 not switching on at once
(a) I am unable to switch on HT XQ100 Home thatre system at once. By continually trying the on off switch will eventually get the unit to turn on and it is fine until you try again the next time.
(b) Once its on it fails to recognize any disk - CD or DVD. It displays "No Disk"
1 Related Answer
Anonymous
  • Posted on Jan 29, 2009
SOURCE: unable to switch on HT
thought I was going to get a response from FixYa - your website said queries answered with no charge - if I had wanted the premium service I would have gone straight for it but as there was no hurry I decided to go for the other option, it does not appear I will receive a solution from you and have therefore taken my unit back to the Samsung service centre for repair.
5helpful
When I turn on the unit I get a symbol that is a circle with a diagonal line through it and then the unit turns off. Any ideas? (Samsung HT XQ100 Home Cinema)
Your fan is bad.
The system is intelligent. It knows it will overheat without a fan. It also knows there is a problem with the fan, so it throws its self into self-protect mode to keep from overheating.
Have a tech check your fan.
;o)
1helpful
2answers
Soundproblems on my Home Theater System
http://downloadcenter.samsung.com/content/UM/200702/20070207171859140_XQ100TXQ100_GB.pdf
Suggest you go back and check all connections with speakers that wires are connected with input properly I have given you web address for manual usually find wires are not bared back enough for connection test each one individually with a tester to make sure there are no broken wires.
1helpful
My device wont turn on (samsung HT-XQ100)
it mite from the overheating its happen to me
3helpful
Tengo un ht-xq100 pero esta bloqueado pues en el display aparece un circulo atravesado por una barra no accede a ninguna funcion y alos 15 segundos se apaga automaticamente
I have sumsung HT-XQ100 DVD player it is overheating even it is in cooled room .... I'm afrid to keep it running for long time ...
could you please helpe my ...
Regards,
2helpful
Unable to switch on HT XQ100 Home thatre system - all I get is a NO ENTRY sign on the front of the base unit instead of the usual D.IN. By continually trying the on off switch will usually / eventually get...
Top Samsung Audio Players & Recorders Experts
ZJ Limited
ZJ Limited
Are you a Samsung Audio Player and Recorder Expert? Answer questions, earn points and help others
