Question about Freezers
Igloo FR1082 making Ice on the inside unit wall. What to do?
4 Suggested Answers
6ya staff
SOURCE:
i_rodrigu37275
i.rodriguez
  • 11 Answers
SOURCE: My Igloo ice 102C is making a loud noise when it pumps in water to make Ice. How do I fix this
It shouldn't make any loud noises at all. Most likely it's a water pump related problem. Most pumps make loud noises when they are lose from their base due to a broken clip or untighten screw. It could also be caused by a faulty pump. Either way, if you just bought it and have the receipt, return it and have them give you another one.
Posted on Dec 02, 2014
drstan69
Stan Naramore
  • 531 Answers
SOURCE: Just received a igloo ice maker followed all instructions it won’t make ice the add water is on and it’s full of water
"The Igloo 100 series portable icemakers that are sold all over for about $100 have several minor issues. For ADD WATER light, there are 2 main ones. The water SENSOR is located at the top right of the unit. Remove the BACK cover with 6 screws on the bottom. Remove the TOP assy with 4 screws from inside the case. When the TOP is off, facing the unit from front, you see the small silver wire at the back right. Clean it AND the screw visible thru the hole in the plastic at the end of the sensor wire. The screw is the GROUND side of the sensor. This fixes many of the issues. But the SENSOR senses water FLOW, not water LEVEL. If the PUMP is not moving water, the sensor assumes you are OUT of water and turns on the ADD WATER light. The pump apparently burns out easily. Remove the PUMP wire connector from the CONTROL BOARD and check for continuity in the motor. Be sure your multimeter leads actually touch the connectors. The connection end is too small for most meters, so probe from the backside of the connector. If motor is good, check for 12vdc at the board side of the pump connector. Plug in, turn on. Should be 12vdc within 45 seconds. See, the water pump comes on first. When water is moving over the sensor, then the board will turn on the compressor and start freezing. "
Posted on Aug 27, 2018
iam6fan
Chris Huff
  • 6289 Answers
SOURCE: igloo ice maker won't make ice. what's wrong?
Water valve possibly defective
Posted on Oct 09, 2018
Where can I get a thermostat for an FR1082 igloo
Sorry we would have no way to know that since we have no idea where you are located. I would say any product dealer can help you
Mar 21, 2017 | Freezers
Igloo countertop ice machine says tray is full when empty and will not make ice
Hi I had the exact same issue after about a year of running my igloo ice maker non stop. To fix it I held in the on/off button and select button at the same time for about 30 sec and TADA!! Back to making ice.
If that doesn't work I've also read to leave machine unplugged for 6 hrs and then hold in on/off button for 10 seconds. Good Luck!!!!
Sep 13, 2016 | Igloo Cooler Igloo Portable Countertop Ice...
Won't pump water to tray.
How a Portable Ice Maker Works - NewAir
www.newair.com/articles/how-a-portable-ice-maker-works/
Look inside to find out how a portable ice maker works, and get some tips about ...Just fill a tray with water, stick it in the freezer, wait 30 minutes or so and, bam, ice! ...Power supply - if the unit won't turn on, make sure if it is plugged into an ... Leakingwater - If the pump is operating but no water is reaching the freeze tray, ...
Customer Reviews: Igloo Portable Countertop Ice Maker ...
https://www.walmart.com/reviews/product/15162429
WalmartIgloo Portable Countertop Ice Maker ... My wife is lazy and never refills the ice traysto put back in the freezer. ... Great ice maker for camping trips and parties. ... even though the thing is completely empty so it won't make anymore ice, and 1/3 of .... My satisfaction was quickly marred by the sheer volume of the water pump in ...
Igloo Portable Countertop Ice Maker - Walmart.com
www.walmart.com/.../Igloo-Portable-Countertop-Ice-Maker/151...
Walmart
Rating: 4 - ‎350 votes - ‎In stock
Buy Igloo Portable Countertop Ice Maker at Walmart.com. ... It features a 3.1L capacity water reservoir that can make up to 26lbs of ice in 24 hours. You need not drain the melted ice ..... A. yes, the ice tray that hold the finished made ice is right about the water reservoir. .... A. Jogie: No, it won't make crushed ice, only cubes.
EdgeStar Portable Ice Maker - Troubleshooting Help ...
blog.edgestar.com/.../edgestar-portable-ice-maker-troubleshooting-help/
Jan 31, 2016 | Igloo Cooler Igloo Portable Countertop Ice...
How do I clean my igloo ice maker
Igloo Ice Maker ICE102-WHITE - Kitchen Appliances Manuals
kitchen.manualsonline.com > ... > Igloo Ice Maker
Igloo ICE102-WHITE Ice Maker User Manual. Page 1. Page 2. Page 3. Page 4. Page 5. Page 6. Page 7. Page 8. Page 9. Page 10. Page 11. Page 12. Page 13.
Igloo Portable Ice Maker Review - YouTube
? 4:02
https://www.youtube.com/watch?v=893Cs66veK0
Jan 3, 2014 - Uploaded by TheVirginiaStew
The Igloo Portable Ice Maker, Model is the ICE 102C Silver and it is great. It can go ... Main thing is to use good ...
Jan 19, 2016 | Igloo Cooler Igloo Portable Countertop Ice...
Why is my igloo portable ice maker hot?
The heat that is being removed from within the unit has to be extracted towards the outside. A lot of times the condenser coils are on the surface just underneath the exterior panels.
Mar 19, 2015 | Igloo Cooler Igloo Portable Countertop Ice...
My 26lb silver portable ice maker wont make ice?? Any suggestions???
does it run? does the compressor run, does the fan run, is the air flowing across the outside radiator, is the air comiing out warm? is there a waterpump and does it run? Does anything get cold and does anything get hot?, it should be. These are my suggestions to look for in your unit
Dec 31, 2014 | Igloo Cooler Igloo Portable Countertop Ice...
Dec 02, 2014 | Igloo Cooler Igloo Portable Countertop Ice...
What does the on off switch for inside the frig "?"
Defrost heater.
It should stop the compressor and turn on a heating element to speed up defrosting.
Jul 15, 2014 | Igloo Cooler Igloo - 10.0 Cu. Ft....
Ice full when no ice portable ice maker
There is some sort of arm that fits into the ice tray; when the ice fills up the tray the arm is pushed up and a switch connected to it will open the circuit and prevent any future ice maker operation(s). That switch has to be closed for unit to work!
Nov 12, 2013 | Igloo Cooler Igloo Portable Countertop Ice...
Freezers Logo
46 people viewed this question
Top Freezers Experts
Dennis Boxerman
John Tripp
John Tripp
Marvin
Marvin
Are you a Freezer Expert? Answer questions, earn points and help others
