Konica Minolta bizhub C250 All-In-One Laser Printer Logo
Posted on Sep 18, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I cannot scan a document to a single email
What my printer does it separates the document into one email per page so i end up getting a string of emails for one document. when i setup the printer on the web there is no option for multipage.
Anonymous
Level 2:
  • Konica Minolta Expert 158 Answers
  • Posted on Nov 20, 2009
Anonymous
Level 2:
Answers
158
Questions
0
Helped
186184
Points
319
File type is probably set to single page. to set the file type to multi page do the following:
1.press the scan button on the op panel
2.select scan setting
3.select file type
4.select multi page multi page to have the entire scan job sent as a single file.
if you are scanning jpeg as file type they will only scan as single page docs only pdf and tiff can be sent as multi page files
2answers
On a Konica Bizhub c364e, how do you scan multiple pages and have them show up as separate files in your email or USB?
Go to Scan/Fax option.
choose your destination.
click on scan setting
on right hand side you will find option SINGLE or
SEPARATE/SEPARATION.
If separate or separation is selected/highlighted thats means all page will be scanned in single file.
if not selected then all single page will create separate file..
How do I scan multiple documents to create a single file for emailing?
In the printer menu under scan you can indicate more than one document and it will keep asking you to change docs until you indicate you are through.
3answers
I seem to have a problem scanning on the KM C351. When scanning a multiple page document I recieve 1 .pdf file per page. This happens whether or not Seperate Scan is selected. Right now the scan are sent...
the file type is set to single page
1.press the scan button on the control panel
2.select scan setting.
3.select file type.
4.select multi page to have the entire scan to be sent as a single file.
if you are sending jpegs they can only be sent as single page files on this machine. only pdf's and tiffs can be sent as multi page files
1helpful
Brother MFC420cn Document Scanning
Yes, you save it to a pdf file. Configure scan to file to save as pdf, and it will create a single file
Scanning multiple pages as a single document
The pages you scan in are each individual "pictures" which are very different than the text in the everyday word processing file. What you can do is to make a new word processing document and insert each of the scanned pictures into this new document in order. This will allow you to print all the pages in one job by printing the word processing document. As far as I know there is no way to scan all of the pages into one single file.
Carl
Scanning 100 pages to my e-mail turns into 10 emails
you can do this with adobe publisher, making a single document out of all of them..
Scan multiple page with X4550
The 4550 will not allow multi page scanning into a single doc using the provided software. You should try another scan software that is TWAIN or WIA compatible. Those should work okay if you are using a USB connection.
Scanners
I bought a different printer.!!!
Scanning 2 page document
Go into the PDS settings and change tab from single page to multiple page.
Scanning several pages and saving as one document
Single scan printers can be difficult in this manner.\
Consider using the OCR (optical character recognition) software that came with your scanner.
Basically the part of the software that asks you what you are scanning (picture, document, newspaper) and make sure to select document. This will enable the character recognition which will convert the scanned picture into a document that you can configure to go into Microsoft Word or Notepad or whatever. If you have multiple pages, it MIGHT give you the option to scan more than one page at a sitting. then again, it may not. In which case you might be kicking yourself for not purchasing the scanner with the auto feed attachment! Once you have made your scanned document in your word processor - READ THROUGH IT! may have converted characters incorrectly - like an "S" may be now a "$" it happens - and it will happen. When done, attach complete document to email and BOOM done.
Either this or use a fax machine :)
hope i helped!
Ryan
Top Konica Minolta Office Equipment & Supplies Experts
Norman Weimar
Norman Weimar
ZJ Limited
ZJ Limited
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
