Question about Locks & Locksmithing
Keypad numbers rubbing off,wanting to order a new #pad
Weiser,looks just like acGED1460X
4 Suggested Answers
6ya staff
SOURCE:
Door Tech
Joseph Chapman
  • 98 Answers
SOURCE: garage door pad
You need to press and release the learn botton (don't hold it or you will clear all the codes)
If the light bulb(s) on your operator are on the front and/or back, the learn botton is on the back of the operator. If the lights are on the sides of the operator then the learn botton is on the right side (looking from the back of the operator and facing the garage door).
After you press the learn button you have about 30 seconds to press in the new 4 digit code in your key pad then hold the enter button until the light on the operator blinks (about 2 seconds). If this does not work check the battery and try it again.
Posted on Feb 07, 2009
jmgldsmth
Jim Goldsmith
  • 2005 Answers
SOURCE: can i get a new touch pad for weiser power bolt
the part can be found here:
http://www.weiserlock.com/Support/Faq/50160000000HhbGAAS.aspx
Posted on Jul 22, 2010
Bill Boyd
  • 53755 Answers
SOURCE: The numbers are wearing off on the keypad of my weiser keyless lock. How can I replace the keypad buttons?
talk with a locksmith as to the availability of the key pad
you may get a new pad but may need to have it reset to the lock you are attaching it to
Posted on Sep 20, 2015
I need and part for my weiser bowerbold.1000, that being the key pad, where can I get one
Hello Clair Hayward,
I ASSUME your entry
"bowerbold"... is a typo... (??)
Look here... (hope I'm helping... looked everywhere else).
Kwikset Weiser Powerbolt 1000 Replacement Keypad 800000 039 eBay
Carnac the Magnificent
Apr 23, 2017 | Locks & Locksmithing
Sep 20, 2015 | Locks & Locksmithing
My unit is not lit up. Impossible at night to see numbers for code
To make the keys light up when you want to enter your code, you have to push the lock button on the keypad first. If the keypad light never comes on, open the door and manually lock the interior lock, then press the keypad lock button. The above instructions should then work.
Oct 10, 2011 | Weiser Lock Powerbolt 1000 Lock
My Weiser Lock unlock fine using the touch pad but will not lock using the touch pad lock button
For your unusual problem I suggest that you call Weiser Lock during business hours at one of these numbers:
For assistance call
1-800-343-9652 USA
1-800-501-9471 CANADA
or visit www.powerbolt.com
Sep 12, 2011 | Weiser Lock GED1460X GED1460X11P Venetian...
My pwerbolt is about 3 years old and has stopped working. I changed batteries and it worked about three times and does not respond when pressing the "lock" button or unlock when locking...
This is the relevant excerpt from the Powerbolt programming and troubleshooting instructions:
"To determine why your lock is beeping abnormally, please follow these steps:
Take out batteries and unplug powerstrip.
Let it sit for 1 minute, then put the batteries back in and wait another minute.
If it does not beep, the keypad needs to be replaced (17733-1).
If the unit continues to beep, the powerboard needs to be replaced (A17734-3,3 Powerboard 1470 brass finish; A17734-3,26D Powerboard 1470 satin chrome finish; A17734-3,5 Powerboard 1470 antique brass finish)."
Since you've already gone through the battery change, try the battery remove-reinstall recommended above. If that doesn't work for you it suggests that you need to replace the appropriate Powerboard for your lock.
So this is the link to Weiser Customer Support Page, where you will find the appropriate number of your location:
http://www.weiserlock.com/en/CustomerService/ProductSupport/SupportContact.aspx
I suggest calling the appropriate toll-free number and having a conversation with a representative about this problem. You will want confirm that you need the part before you go through the expense, and that it's worth it. You will need to know the "finish" of your lock. Try to talk them into warrantying the part, in spite of the age (one year warranty on electronics), as a matter of good customer relations. They will help you get the correct part on order.
Good luck--and please provide feedback if this helps!
Aug 23, 2011 | Weiser Lock POWERBOLT ELEC DEADBOLT
I need to reprogram the keypad
First, push the program button on the power board once. Enter the four to eight
digit code by pressing the numbers on the outer touch pad. Press the lock button on the
lock button on the touch pad to set the code. You will hear a two second long beep when
your code is accepted. If the unit does not beep, too much time has elapsed between pressing
the program button and entering the code. Repeat the programming sequence. Enter your number
to check that it works.
Jul 27, 2011 | Weiser Lock Locks & Locksmithing
My weiser keypad just keeps beeping
Why is my Powerbolt 1000 unit beeping?
The complete page that I cut this from can be found by cutting and pasting this link into your browser search bar:
http://www.weiserlock.com/Support/Faq/50160000000HhhZAAS.aspx
This suggests that you need to replace the appropriate Powerboard for your lock.
So this is the link to Weiser Customer Support Page:
I suggest calling the appropriate toll-free number and having a conversation with a representative about this problem, first of all to confirm that you need the part before you go through the expense. Secondly, your lock may be new enough for you to talk them into warrantying it, and thirdly, they will be able to get the correct part on order for you.
Jul 23, 2011 | Weiser Lock Powerbolt 1000 Lock
F1 code what is it
F1 Defective Touch Pad or Membrane Replace Touch Pad or Membrane
Tip: Get a hot dish towel and rub that hot towel onto the keypad to free up that sticky keypad before ordering anything.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
May 27, 2011 | Jenn-Air JGS8750 Gas Kitchen Range
# keypad rubbing out
Yes, they are replaceable.The keypad cover peel off and the replacement cover sticks on where the old one was.Warning!! make sure you have a new one before you remove the old one.Good Luck
Apr 06, 2009 | Canon ImageRUNNER 1670F Copier
Locks & Locksmithing Logo
Top Locks & Locksmithing Experts
john h
ray gallant
ray gallant
Andrew Taylor
Andrew Taylor
Are you a Lock and Locksmithing Expert? Answer questions, earn points and help others
