Question about Kenmore Freezers
How do I reset the reset button on my Kenmore freezer after a power outage
4 Suggested Answers
6ya staff
SOURCE:
peyton32034
peyton thompson
  • 410 Answers
SOURCE: my kenmore upright freezer quit working after power outage
is there any lights on in the freezer? try plugging the freezer into an outlet you know is working. there is no "reset" on the freezer so if lights are on and it still isnt working it could possibly be stuck in defrost or the thermostat could be stuck in the off position.
for the defrost problem: pull freezer from wall and look in the compressor area and you will see a control under the unit left of the compressor. using a flat blade screwdriver advance the timer clockwise a few clicks and it will probably come back on. if that doesnt work lets check the thermostat.
thermostat stuck: this is easy but you need to check def timer first. using the handle of you screw driver tap the thermostat knob firmly. if the contacts are stuck open when you hit it the contacts will release and the unit will come back on.
hope this helps..
Posted on Dec 13, 2007
Anonymous
  • 124 Answers
SOURCE: Kenmore freezer quit working after power outage
simple stuff, you have a compressor a stat and power. check the receptacle to be sure you have 120 volts . then check the compressor with stat at max cold setting to see if you have 120 volts at compressor. if you do then compresssor is bad =new compressor or new unit. if no power to compressor then stat is bad= new stat. i always recomend new unit cause new stat or compressor wont fix a freon leak.... i have replaced a few compressors that died soon after due to a freon leak. good luck...
Posted on Nov 27, 2008
Stephen Matthews
  • 107 Answers
SOURCE: how to reset a samsung refrigerator model number rs261mdpn aftthea power outage
http://www.searspartsdirect.com/partsdirect/part-number/Samsung-Parts/Refrigerator-Parts/DA41-00669A/0046/401/Model-RS261MDPNXAA/1482/0165000
this is the control board you will need for your model if unplugging the unit for 5 minutes doesn't fix the problem. If they are LED lights, then I point my finger at this. This is a plug and play board with molex connectors. Very easy to install with unit unplugged. You can manually reset the display and check for error codes by holding the top left and top right button on your user interface for 5 seconds in unison FOR 5 or more seconds after all the lights flash.
Posted on Feb 01, 2015
How to reset Kenmore chest freezer after power outage
It should come back on automatically when power is restored. If not you could have had a power spike or low voltage and caused damage.
Oct 20, 2017 | Kenmore Freezers
I have a kenmore upright freezer model / 970-187020 and we had a power outage and now my temperature control is not working right and it says OFF all the time.
Sometimes when the power comes back on you get a power spike or low voltage, this can damage electrical components.
Aug 14, 2017 | Kenmore Freezers
Kenmore upright freezer not cooling after power outage of 3 hrs
Try resetting the temperature adjustment. Back to zero and then to desired setting again.
May 19, 2017 | Kenmore Freezers
Ffu14f5hwn how to reset control after power outage
Good Afternoon Friend,
I understand that you are trying to reset the controls on your Frigidaire freezer, model# FFU14F5HWN, after having a power failure. To reset the control after a power outage, all you will need to do is press the "Alarm Reset" button. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your freezer status has changed successfully. Hope this is helpful.
-Best Regards-
WP
May 16, 2014 | Frigidaire Freezers
Can not set the controls
Look for a reset button/switch and reset it or go to your local homedepot because they have a 800 number you can call to help you fix it yourself.
May 04, 2010 | Kenmore 20.3 cu. ft. / 575 liter Upright...
Power outage and freezer is now flashing "e" on display
look on the inside of the toe kick at front bottom or just inside front bottom and you will find a tech sheet that will give you error codes.
Jul 26, 2009 | Kenmore Freezer 20.3 cu. ft. Frost Free...
Kenmore upright freezer no digtal light no motor running
if it is an electronic control freezer then the electronic control sounds as though it has failed if there is no digital read out
May 02, 2009 | Kenmore Freezer 20.3 cu. ft. Frost Free...
Nov 23, 2008 | Kenmore Freezer 20.3 cu. ft. Frost Free...
Cannot reset the temperature on my freezer
What is the manufacturer of your freezer?
Jun 26, 2017 | Freezers
My kenmore upright freezer quit working after power outage
hope this helps..
Dec 13, 2007 | Freezers
Freezers Logo
102 people viewed this question
Top Kenmore Freezers Experts
John Tripp
John Tripp
Felizardo Erilla
Felizardo Erilla
PNiss
Are you a Kenmore Freezer Expert? Answer questions, earn points and help others
