SOURCE: what does H4-04 error code mean on a Sharp MX5001N
H4 Heat roller lowtemperature detection resetcode 14
SOURCE: sharp mx5001n...what is error code c4-02 and is
This is the problem with the PTC unit,
in order to get this problem fixed you need to get the ptc unit replaced.
To do the same you will have to call sharp.
what you need to do is just resetting your machine.
1. Press * 28 * on your machine in a quick move.
2. Select copier
3. Select Err.
4. Select Clear then press O.K
5. Turn your machine off for 1 minute and turn it on again.
The error code will not be there anatmoreand your machine will be functioning well.
