Question about Dewalt Tools & Hardware - Others
I have a Dewalt DC608 which is firing brad nails but not sinking them right in. I guess I need to replace the bands and/or Grommet. I need help with step by step instructions please
  • Terry
    Terry Oct 23, 2019
    This model was recalled years ago due to safety issues.
    https://www.dewalt.com/support/safety-no...
    Manual mentions low battery and other issues that might cause your issues.
    https://www.manualslib.com/manual/111065...
    Habit-Forming:
  • 47 Answers
I’m not trying to be a wise guy but the regulator has an adjustment on the bottom
Posted on Oct 24, 2019
6ya staff
SOURCE:
Anonymous
  • 3 Answers
SOURCE: installing brad nails
Pull the clip in the loader slot. Insert staples point side down. Slide loaded loader clip into place till you hear a click. You are now ready to staple! Enjoy, and make sure to staple the dog somewhere funny.
Posted on Oct 22, 2008
rowdy45176
David Ford
  • 2176 Answers
SOURCE: how do I load nails in Stanley powershot staple/brad nails
you can try and go to Stanleytools.com and get to their knowledge base of FAQ or they have a direct way to contact the company for the information you need. I was on their site and have seen better to help the end user.
Posted on Dec 30, 2008
John Trevino
  • 1420 Answers
SOURCE: brad nailer not firing nail...can hear brief air noise upon pulling the trigger
Porter cable makes a number of brad nailers (18 gauge) that very quickly suffer from the problem that you are having. You did not mention the model number of your gun but if it is one of these, (bn125a, bn200a, ns100a) kit # 60061 will fix the problem. It costs between 25 and 30 dollars. Google that part number or order from www.dewalt.com. Dewalt owns the porter cable brand. Before you order the kit, check that the driver blade is not bent and stuck. The driver should travel freely down the cylinder. When you install parts, use Danco silicone grease to lube (availabel at Lowes in the plumbing department) If your model # is different from those mentioned above, please email me and I will recommend a repair.
Posted on Apr 27, 2009
Joe Hogan
  • 10865 Answers
SOURCE: Bostitch nail gun loss of pressure, won't fire nail
Hello. I can help you. The nail gun you have uses 18 gauge brads. I would use only original Bostitch 18 gauge.
The one MM of difference you mention is the reason why you do not have the pressure you did have. Get rid of those 31MM brads and get the 18 gauge. Home Depot carries the Bostitch line. I would go there or to homedepot.com
Posted on May 20, 2009
Anonymous
  • 8 Answers
SOURCE: nail gun wont fire
First - the air pressure has to be high enough - check the regulator on the tank to make sure it is delivering in excess of 60-70 psi (which I am sure you have already done).
If you have dry fired these guns (i.e. shot them off with no nails in them while you were lubricating them maybe) the mechanism inside could be damaged. I had that happen to one of my nailers (same brand). That was when I learned not to dry fire them...
Since both of them are not working though I would be more inclined to look at the air supply first.
Posted on Sep 10, 2009
Dc618 brad gun wont fire on bump
The link below is where you can download the owners manual. The link is on that page near the top right hand side under the area marked downloads. Page 5 will show you were the switch is located that switches the tool from sequential fire to bump fire.
DeWalt DC618 parts and operations manuals
Jul 07, 2012 | Dewalt DC618KA Angled Nailer Kit
My brand new DC608 18 gauge nailer jams every time on the 2nd nail.
Per your addendum I would have first told you to check that you are using the proper guage nails. Second you should make sure you are loading the nails in the lowest channel in the magazine so they are at the bottom of the magazine. If you load them into the top of the magazine they have more time to go off course before they get into the wood.
May 29, 2012 | Dewalt Heavy - Duty 18 Gauge 2" Brad...
I have a DC608 cordless nailer that will not fire the driver the driver does not move at all but everything else seems to be functioning properly Thanks Tim
You can go to this webpage and download the owner's manual which gives instructions: http://servicenet.dewalt.com/Products/Detail?productNumber=DC608K
You can also download a parts diagram and order parts here.
I looked through the manual and found that DeWalt's Brad Nailer does not require tools to remove jammed nails from the nose piece. I believe this is the problem with your nailer, unless it's empty. Some of these nailers will not fire if there's less than 6 nails in them.
Another feature on this nailer is the trip lock. It is a safety feature that prevents accidental firing. Any time you adjustments made to the nailer will automatically turn the trip lock to lock position. You'll find this lock on the right side, under the Dewalt label.
The instruction manual will explain all this.
Hope this helps. If it does, I would appreciate a vote. Thanks,
Handie Andie
Apr 01, 2011 | Dewalt DC608K 18 Gauge 2-inch Cordless...
Dewalt d51238k gun fires but no nails
Make sure the area where the nails slide through is nice and clean. Lubricate with some spray silicone. They may not be seating all the way against the nail driver mech.
Feb 28, 2011 | Dewalt Heavy - Duty 18 Gauge 2" Brad...
The gun won't put out any nails anymore......It is a cordless bradnailer..
If it is the cordless Brad Nailer and will not fire nails anymore chances are the drive belt came off track. Internally those DeWalt cordless nailers operate much like a Baseball pitching machine. And when you fire a nail the drive belt pinches the driver blade which fires the nail. Here is the product documentation from DeWalt's website. http://www.dewaltservicenet.com/Products/DocumentView.aspx?productid=68728&typeId=16768&documentId=35981
The Drive belt is part #59. I have never opened one of these before so I can not tell you if it is a simple fix, I would open it up and peek around just a few screws on the top should open it. If you do not feel comfortable opening that unit yourself, I would take it to an Authorized DeWalt repair facility.
Oct 09, 2010 | Dewalt Heavy - Duty 18 Gauge 2" Brad...
Brad nailer not firing nail...can hear brief air noise upon pulling the trigger
Apr 27, 2009 | Porter Cable 18 - Gauge Brad Nailer and...
Dewalt nail gun
if ur nail gun is DC608 it on recall. if it other model it could be the return assy or the pc board.
Sep 10, 2008 | Dewalt DW715 Heavy Duty 12" Single -...
Tools & Hardware - Others Logo
Top Dewalt Tools & Hardware - Others Experts
John Trevino
Ruben Bustamante
john h
Are you a Dewalt Tool and Hardware - Other Expert? Answer questions, earn points and help others
