IGLOO206-TG-SILVER will only come on intermittently after a power surge. Will get halfway through cycle then go dark again. Powers back on when it wants to, apparently... Ideas?
6ya staff
SOURCE:
Geekman
Chris Hingee
  • 32281 Answers
SOURCE: my delle173fpc powers up then goes dark if i
You could have a faulty inverter board that supplies high voltage to the CCFL lamp or a faulty CCFL lamp.
Check out LCD Parts for service, parts and DIY info. click on this link to their WEB site :-
www.lcdparts.net
Posted on Nov 06, 2009
Michael Ibot
  • 235 Answers
SOURCE: cycles on and on
try replacing your power supply or better yet try to replace your memory, if you have any spare, i encountered this problem with an imb socket 478 motherboard, the power supply is good but there is no display nor any beeping sound, i though that the power supply would be the problem but not when i change the memory module it boot up nicely and has no problem ever since
Posted on Nov 20, 2009
Azrael SRL
  • 11800 Answers
SOURCE: PC is stuck in reset cycle during boot up. Reaches
Read this http://www.geekswhoknow.com/articles/stop-0x00000024-0x0000024-0x24-ntfs-file-sys-error-code.htm
If you don't have a floppy then you can use
http://partitionlogic.org.uk/   to try to fix the partition.
If you want to recover your files before messing with the failed partition then just boot from a Linux Live-CD and move your files on a USB stick.
Posted on Apr 02, 2010
Grubhead
Grubhead
  • 5699 Answers
SOURCE: Sansui AU-X410R Amp, at power on, lights on but no sound.
One thing you could look at is that thing that makes the click, it could be a relay and they do go wacky sometimes (hence why it shuts down). If you are lucky it will tell you (on the relay) everything you need to replace it.
Posted on Jun 12, 2010
djmichaeltra
djmichaeltra
SOURCE: Sharper Image Hybrid GP. Unit powers on, goes to
The solution drgoff provided ( the guy that used to work for Sharper Image ) actually did the trick !!!! Super excited to have this unit working again , thanks drgoff
Posted on Aug 02, 2012
I have a Vizio XVT473SV with no video or audio, but the Vizio standby lights up.
I would say its most likely the power supply. Quite often after a power surge this can happen. Another option could be that the surge just blew the fuse on the power supply board and replacing that may be all you need. That said, usually you will get no signs of life at all if the fuse blows.
Jan 22, 2018 | Vizio Televison & Video
TG 9201 IS UNPLUGGED
Does this phone system have a central server? If so I would go check to see that it has power and came back up after the power outage. A lot of phone servers are on a battery backup and when the power goes out the software tells the server to shut down and then the UPS powers off.
Mar 17, 2014 | Inter-Tel Axxess Corded Phone
Video Disappears Intermittantly
The TV power supply may be failing.
Oct 19, 2017 | Vizio VP322 32 in. Plasma TV
Have Vizio TV, powers on, but blank screen, no backlight
Its probably damaged the board that powers the backlight in the surge. Repairs on this depending on the size of the TV might out way the cost of replacement. I
Dec 05, 2013 | Televison & Video
Duromax next generation xp10000E idle surging problems
I have a duromax 16hp engine on a murry go kart ran perfectly fine we took engine off kart painted kart put motor back on go kart now wont idle unless holding choke halfway open and new gas we drained gas before we started work on kart plesas help only about 10 hrs
Dec 26, 2012 | DuroMax XP10000E 4-Cycle Gas Powered...
After a power surge yesterday my hotpoint dishwasher is doing this halfway through the cycle. It doesn't finish the cycle - water stays cold and it doesn't dry the dishes - any ideas's? The model is
Try cutting off the power to the dishwasher at the breaker box to reset the memory board ( for 15 sec.) then turn the breaker back on. If this did the trick good if not then the power surge may have over powered the board inside.
Oct 14, 2012 | Dishwashers
Carriage will not return
the silver shaft that the carrier moves back & fourth on is gummy take a rag & put some light wait oil on it wipe the silver shaft down. With the power off move the carrier back and fouth. spray or put on more oil on shaft wipe down any extra oil.
Jan 22, 2009 | Lexmark Wheelwriter 15 Series II...
Ibm thinkpad laptop plugged in powers off after about 15 minutes
Have you checked the power settings in the BIOS set up? There are ways to automatically turn off machine there.
Dec 10, 2008 | IBM ThinkPad T43 Notebook
Powers off after 15 seconds to 1 minute
solder issue at the flyback. try resoldering the flyback
May 17, 2008 | GE D52GW12 52" Rear Projection HDTV-Ready...
Televison & Video Logo
21 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
