Question about Dryers
I have an electric drum set called the Typhoon TYDD-01 THATS AN ELECTRIC DRUM SET. i need the manual please.
Electric drums manual called a Typhoon mod. TYDD-01 its a few years old. Call my cell 289 237 3856
6ya staff
SOURCE:
Anonymous
SOURCE: ion ied05 Electric drum
I hear it is only on a cd that comes with the set. I am expecting in a few days. Check to see that it is not included with the software you received. Let me know as I will be installing in a few short days.
Posted on Dec 29, 2008
TheMobilian
Dan Webster
  • 8220 Answers
SOURCE: Roper Electric Dryer Heats but drum won't spin
Yank the filter out the top. Remove the 2 screws in the filter housing. Use a putty knife to pop the top and then remove the screws holding the front on. NOTE: raise up on the front panel slightly so you won't damage the bottom clips. Get the front out yer way and remove the drum. Clean out the dryer and oil the rollers and idler. Use this handy ROUTING GUIDE to see how to put the belt back.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Posted on Jan 20, 2009
lenwest
Len West
  • 150 Answers
SOURCE: Whirlpool duet electric dryer - drum turns; no heat
Turn off the breaker and check the heating element.
for more help go to live chat.
hope this helps
len west
Posted on Jan 30, 2009
Sal De
  • 2699 Answers
SOURCE: Drum rotates. No Heat. Kenmore Electric Dryer
check the thermal fuse on the top of blower wheel housing,also while your there take off the cover of the housing and clean all the lint out,if your fuse was popped the lint buildup did it,check outside and make sure the air from dryer is blowing out and is not blocked,if it is blow out vent line if it's a long run with a leaf blower,if the thermal fuse is good read out the heater with a meter and if that's good read out the t-stats
Posted on Nov 15, 2009
Testimonial: "Bad heating element. Ordered replacement found on Internet."
heatman101
D. Floyd Kolb
  • 43501 Answers
SOURCE: Bosch Axxis electric dryer, 3 years old, dryer
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The Dryer is not Turning
https://www.fixya.com/support/r4422207-dryer_repair_dryer_not_turning
Dryer Repair ? The dryer will not start
https://www.fixya.com/support/r4460438-dryer_repair_dryer_will_not_start
heatman101
Posted on Aug 23, 2010
Dryer won't start cycle, stays on sensing
It sounds like the pullies (drum guides ) need attention the motor is having trouble rotating cause of pressure of not being balanced ,
May 13, 2014 | Maytag MED6400TQ Electric Dryer
I am going to buy an electronic keyboard for my kids, maybe with a drum set etc too. Are there any makes that people can recommend that I look for?
I always buy Yamaha or Casio when it comes to electronic keyboards for kids. I think their products are well made but also are more affordable than some of the more professionally aimed products.
Feb 25, 2013 | Toys
Hi, do you know what the rubber ring around the middle of the drum is, because my daughters Zanussi 37100 had some-thing stopping the drum from turning, so we have taken the top off and noticed that this...
I searched and read the user's manual for your unit, I could not find a service manual or "exploded" view so I will answer the question based upon other dryers I have repaired. I was impressed by the design of the dryer and it looks as if it is a nice appliance. Most dryers drums are indirectly driven by an electric motor via a pulley and belt arrangement. The belt is wrapped around the drum and tracks through a pulley/spring to the electric motor. The belt wears out eventually usually dependent of the age and the load applied. If your drum does not rotate or you have heard a squealing noise then your belt is probably in need of replacement. A DIY person can change it but if it is your first time take some precautionary steps: Use a camera to record your work, Check to see if you can get the belt, in your area. And plan to spend the majority of the day doing the job. And since you say that it is still working... use it. If the squeals or the drum stops turning then the belt will need replacement.
Feb 11, 2011 | Zanussi ZDC37100W Electric Dryer
I have a FP Electric Dryer DEGX1US and it is squeaking like crazy! Can you help?
more than Likely the rollers that hold the drum,, you have to remove the drum (be sure and look before to see how the belt tensioner is set up) pull the drum, Lube the rollers , and reassemble
Aug 02, 2010 | Fisher and Paykel DEGX1 Electric Dryer
For Sale Brand Korg OASYS 88 88-Key Workstation ????2100.00 EUR
If you scroll to the bottom of the page and click on Advertisers the site can help you.
Aug 05, 2009 | Music
Dryer drum will not turn
check to see if there is a little red button on the back if so push it in thats your re-set button
Mar 24, 2009 | Dryers
G. E. Electric Dryer - on drying rotation making noise
Drum bearing is worn out and needs replacing. There is an axle on the drum that goes into this bearing. I cannot see your repyl due to some tech issue w/ the site, so it may be a day or so before I can reply again. Please leave feedback for me if appropriate. Thanks
Nov 28, 2008 | GE DBSR453EBWW Electric Dryer
ASKO t700 dryer thumping sound
usually whin you get one thump (or a quick double thump) you have a dent in the roller surface of the drum itself. Easiest way to check this is to unplug the unit and take the top off by removing the 3 torx screws in the rear, then lifting the top off. Once the top is off look at the very front edge of the drum as you rotate the whole thing by hand. If you see any irregularities on the surface, thats your problem. If you see nothing it could be a bad motor or roller, but its unlikely if its happening in the same place on the rotation evry time. What has usually happened with dents in the surface of the drum is that the unit was set down too hard (or dropped) and the wheels it rests on dented the metal they ride on. If thats the case the only solution is to replace the drum or live with it .Good Luck!
Feb 10, 2007 | Asko T700 Electric Commercial Dryer
Dryers Logo
54 people viewed this question
Top Dryers Experts
Marvin
Marvin
jimorris77
