Magicolor 2400W. Not used for a while. paper feeding didn't work so disassembled cleaned and reassembled. Now it makes no attempt to feed paper pickup roller never moves and I have rapidly blinking Ready and error lights PLUS rapidly blinking Yellow and Black toner lights. it does this as soon as power is switched on - before even the standard rotation of the toners
IT is 16year old today, and there are no spare parts, for it.
cept used on ebay.
the blinking lights in the manual mean, toner cartridge dead or fake one installed. on page 11.
if got it to work there are no windows 10 drivers, now. XP yes.
see that page 11 states on errors.
https://www.manualslib.com/manual/90066/Konica-Minolta-Magicolor-2400w.html?page=11#manual
the service manual is here,
https://www.manualslib.com/manual/805991/Konica-Minolta-Magicolor-2400w.html
RTM?
SOURCE: Konica Minolta 2400W Magicolor. Error light blinking
Ready indicator Error indicator Condition Action
Green Orange
Blinking Blinking Communication Check The Printer
error cable
____________________________
Print over-run Turn off the printer.
After a few seconds
turn on the printer
change to a lower
resolution.
________________________________________________________
This may help if not...let me know........Whytfang
SOURCE: Paper feed issue
You didn't setup the paper size correct, check again in the driver and
application to have the same dimension with the actual paper in printer.
Reset your Toners and Imaging units for Bizhub and CF series.
http://www.chipreset.eu
SOURCE: Error light flashed when trying to print with Magicolor 2400W
Start the Konica Minolta Status application and check the error, you should get
more info there.
SOURCE: konica minolta magicolor 2400w
The possible reason for error is the printer does notread chip on the cartridges.
The reader for chips locate inside the printer bottom ofcartridges.
Take out all cartridges and you see reader it is a small blackplastic which come three contact plates.
Just clean it with compressed air and take out if some contactplate is sedentary.
Thanks for the service manual
I'll take it apart and have a look when I have some more time
