Question about Philips Magnavox Learning Universal Remote
I have philips cl034 remote i need t.v. codes.
I need t.v coeds for my remote can you help?
    President:
  • 1,126 Answers
Http://www.remotecentral.com/cgi-bin/files/rcfiles.cgi?area=other&db=devices&br=philips&dv=universalremote&md=cl034&kw=&st=&ar=&dt=&so=&pg=1&file=others/philips/cl034-codes.zip
This link will allow you to download instruction manual for your CL034, however it is in .zip format..... you wil need to unzip (extract) it to view.
Posted on Sep 18, 2009
6ya staff
SOURCE:
Anonymous
  • 944 Answers
SOURCE: universal remote
Which TV do you have? :)
Posted on Aug 28, 2007
Anonymous
SOURCE: in need of codes for philips universal remote CL034
Here is an alternate way of programing... 1) Manually turn on the device (TV, DVD) to be controlled. 2) Press and hold code search button until the red indicator stays on. Release the code search button. 3) Press and release the desired mode button (TV, DVD,etc) 4) Press the Channel Up button repeatedly (up to 300 times) until the device to be controlled changes channel. 5) Press and release the Mute button to install the code.
Posted on Sep 27, 2007
IrishDruid
Swilin Sampson
  • 2712 Answers
SOURCE: yes i need all the codes for my cl034 universal philips 4 remote
Symphonic - 0171
Apex - 0156
You can find the remote control codes for different brands of devices from
http://www.hifi-remote.com/ofa/codes-tv.shtml#tv
If none of the codes work then we have two other solutions:
1. Searching For Your Code
If you have tried all of the set-up codes for your brand of equipment ,or your brand is not listed, and you are still not able to get the unit to respond, try the following procedure to search for your code.
If you don't find a code that works, the remote will flash four times when you reach the end of all the codes for this device type.
  1. PRESS the button for the device you want to program, (TV, VCR, CABLE, etc.), then RELEASE.
  2. PRESS and HOLD the SETUP button until the red LED flashes twice, then RELEASE.
  3. ENTER 9-9-1 (two blinks on the remote)
  4. ALTERNATE slowly between the POWER key and the DEVICE (TV, VCR, CABLE, etc.) button until your device turns off. (On VCR, LD, and CD players use PLAY instead of POWER)
    Make sure that the remote is pointed at your device during the search, You may have to press this sequences of buttons up to 100 times to search the entire library of codes.
  5. When your device turns OFF, PRESS the SETUP button and RELEASE it to lock in the code for your device.
2. Learn the buttons from the original
Line up your original remote and the head-to-head before completing the following steps.
  1. PRESS and HOLD the SETUP button until the red LED flashes twice.
  2. PRESS 9 - 7 - 5, the red LED will flash twice.
  3. PRESS the DEVICE key where you wish to learn the function. The next 3 steps must be completed within 10 seconds.
  4. PRESS the button that will receive the learned function, the LED will flash rapidly.
  5. PRESS the button on the original remote to be learned.
Now you can repeat steps 3 through 5 to learn other functions onto other keys or press and hold SETUP until the Cinema's red light flashes twice to lock in your new feature. (If the red light does not blink twice, stop and repeat steps through 6).
To test the new feature, press and release the device key in which the new feature was learned followed by the key on which the feature was learned
More help for programming your remote can be found here:
http://www.hifi-remote.com/manuals/ofa-l.shtml?URC-7800#device
Hope that helps!
If your issue is not resolved, please do not assign a rating just yet. Please post back as to what steps you took, results, etc, and I will try to assist you further as best I can. I am here at your service.
P.S. -You can rate this solution with one of four votes, if you feel your issue is resolved (remember that at times a bit of to and fro dialogue may be necessary to resolve an issue).
  • "FixYa!" - The solution provides great advice on how to solve the problem.
  • "Helpful" - The solution provides useful leads that helps solve the problem.
  • "Thanks for Trying" - The solution does not solve the problem but the effort is appreciated.
  • "Inappropriate" - The solution has absolutely nothing to do with the problem.
Thank you for using FIXYA!
IrishDruid
Posted on May 08, 2008
Anonymous
  • 23 Answers
SOURCE: remote codes
GE ........... 0704 0312 0018 0002 0502
................. 0006 0007 0601 0835 0901
................. 0114 0103 0803 0806 0310
1. Press and hold the CODE SEARCH
on, then release the CODE SEARCH
button.
2. Press and release the desired Mode
button (TV, VCR, etc.). The red
indicator blinks, then stays lit.
3. Enter the 4 digit code from the code
tables. Note: after a valid code entry,
the red indicator turns off. For an
invalid code, the red indicator
flashes.
4. With your device on, press
CHANNEL UP. If the device
responds, no further programming is
required. Note: If some buttons do
not operate your device, try one of
the other codes for your brand.
Posted on Jun 26, 2008
the q guy
Tony Walker
  • 393 Answers
SOURCE: Philips Universal Remote #CL034- Need tv codes.
I found that these websites should have all the codes and instructions for most remotes
http://www.xdiv.com/remotes/
or http://www.remote-codes.com/
let me know if this helps
Posted on Jun 25, 2009
Please I need a kenmark remote for 19lvd10di. I just bought it new, but it has no remote. plz help.
There are a couple of online sources with replacement remotes for the Kenmark 19LVD10DI . Amazon.co.uk is one source; see http://www.amazon.co.uk/Replacement-Control-19LVD10DI-batteries-included/dp/B003W4IQ5W or http://www.amazon.co.uk/RM-Series-Replacement-Control-KENMARK-19LVD01D/dp/B007WDKFLM/ref=pd_cp_23_2/277-5560654-4659337?ie=UTF8&refRID=1AY3QJQKK6MAW3HKGZDF . This is another: http://www.partmaster.co.uk/kenmark/kenmark/kenmark/19lvd10di/catalogue.pl?path=99178,596395,596395&bsid=12616&mid=1420378 .
I hope this helps. Since you bought the TV new, you may want to talk to the vendor. The remote should have been included (open-box or floor models might not have the remote).
Jan 15, 2016 | Televison & Video
Need a maual for JVC MX-D302T
JVC has the manual available for the MX-D302T here: http://www.jvc.co.uk/files/instruction_manual/ib_mxd302.pdf . This is a PDF so you will need Adobe Reader or a similar program to read/print the file. You can special order a print copy of the manual and the remote from http://www.partstore.com/Model/Matsushita/JVC/MXD302T.aspx . Scroll down to find them in the parts list.
If you want to order the remote separately, remotes.com has a substitute remote from JVC for sale: http://remotes.com/store/jvc/mxd302t.html . Amazon also has a replacement remote available: http://www.amazon.co.uk/Remote-Control-Replacement-JVC-MXD302T/dp/B005LQA4JK .
I hope this helps.
Nov 18, 2012 | JVC MX-D302T Shelf System
Need a code for zenith tvs on one for all remotes
Try this website www.oneforall.co.uk or www.tvcodes.com Let me know if this was helpful or if you need more help.
hardrocko
Feb 03, 2010 | One For All URC-3021 Remote Control
Remote code required for UK Bush tv model WS6680SIL/C7
Found the correct code for my TV & Sky remote... I searched a fair bit more on google for... "WS6680SIL/C7 code" and found... http://www.sjstv.co.uk/skycodelistNEW.html which the correct code for my Bush TV - 0742. Others you may want to try are Bush 0157 246, 263, 377, 037, 064, 065, 310,300,383, 399, 391, 402, 339. or Beko 0125 514, 398. Further, Alba Group are the firm whom own Bush brand amongst others. Google Alba Group to get their site and links to Bush sites.
May 20, 2008 | Bush WS6671 28" TV
Need coeds ,help
Hi ms lamb,
here is a link to your Zen350 controller and the codes for it:
http://www.remotecodelist.com/remotes/zenith/zen100-700.pdf
Mar 29, 2008 | Zenith ZEN350 Remote Control
Codes to program Innovage Products Jumbo Universtal Remote
I need the code for my rca tv so I can program the inovage jumbo universal remote Pleaseeeeeeeeeeeeeeee
Dec 31, 2007 | Televison & Video
Philips Magnavox Learning Universal Remote Logo
933 people viewed this question
Top Philips Televison & Video Experts
ThaMp3Doctor
ThaMp3Doctor
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
