https://help.brother-usa.com > answers > detail > a_id
The message "Unable to Clean 5A" will appear on the display for one of the following reasons: i. A foreign object, such as a paper clip or ripped piece of paper ...
https://www.youtube.com > watch
PREVIEW
2:56
brother #Brotherprintererror #Brother5Aerrorthank you so much for watching please like,share and subcribe my channelYOU GET ERROR LIKE THESE ...
YouTube · Shivam Sharma Repairs · Jul 15, 2020
Check carefully that you have specified it to use the # 10 and that the format does not include a wide margin. If that fails, try printing the Return address 'right justified' and see what happens.
As you've noticed, the Brother printer goes offline with a single update to Windows 10. Even so, Windows 10 updates or driver upgrade is not the only cause for your printer to be offline. The key reason behind a brother printer that displays an offline message in windows 10 is the connectivity issue.
Reasons that cause Brother Printer Offline:-
1.As cable disconnection could also be a reason for the Brother printer offline issue.
2.Faulty USB connections can arise printer offline
Step to fix Brother Printer Offline Windows 10
1.Verify the Brother Printer turned ON and there are no errors on screen.
2. Make sure the Brother printer is connected to the computer properly.
3. Make sure your Brother Printer is set as the default printer in Windows 10 settings.
4. Delete all print jobs from the printer properties option.
If there printer is not able to print on card stock then check the recommend card stock paper thickness, if the printer works with normal paper but not card stock then there is problem in the card stock and by using this paper may also damage the rollers on the printer and make the printer useless ...
