Can't change listening mode to surround sound
    Top Expert:
  • Audio Player... Master
  • 10,535 Answers
2 Suggested Answers
6ya staff
SOURCE:
ryancsmith
Ryan Smith
  • 62 Answers
SOURCE: no sound in listening modes except pure audio
Check the input mode on the reciever so that they are set for dual, rather than just digital or analog. It might be set for analog and your using a digital optical in cable. Also make sure DTS mode is turned off, unless your watching a DVD that is dts enabled.
Posted on Aug 06, 2009
Center speaker problem on pioneer vsx 40 .I hooked up the center speaker and I can’t get sound from it
Most problems are menu settings, because surround modes can be complex and confusing. Verify what surround input type you are using. FM tuner will not play center spkr unless put into a simulate or expand stereo mode. Do other surround speakers work other than normal L/R stereo mode? You can try redoing your auto surround setup (MCACC) or going to the manual speaker setup and verifying speaker is turned on in menu system. Rechech you listening mode setups at Pages 33,38,39 in your manual. Try another speaker and wiring on center output. Try Different surround inputs, some manufactuers have had problems with their DTS and HDMI boards. Otherwise take to repair.
Nov 22, 2017 | Pioneer Audio Players & Recorders
I have a JVC TH-S3 surround sound system and would like to know if I can l watch television in surround sound as i can watch dvd's and listen to the radio in surround sound. thanks
Yes you can get simulated 5.1 surround sound from your TV as well as radio. Just switch the JVC surround mode to Pro Logic II movies or music In some systems it will display only PLII.
Just connect the TV audio out to the JVC Aux input at the back ( red and white sockets ).
Apr 26, 2011 | Audio Players & Recorders
VIZIO VHT510. soundbar and subwoofer work. No sound from satellite speakers
Do you have them connected to the sub? Those satellite speakers pick up the fainter sounds and work best in movies with 5.1 surround sound. Make sure they are behind the primary listening position. And try them with a 5.1 surround movie. If all speakers are up front switch to front listen mode. Good luck.
Mar 06, 2011 | Vizio VHT510 Theater System
The sound coming out of the surround sound speakers sounds like it is under water,but sounds great on 2 channel mode
Surround modes usually process the sound to make it appropriate for the direction from which you'll hear it (ambience, echo, reverb, spatial cues).
Surrounds are not meant to be listened to alone. Does the sound from the surrounds mesh with or enhance the other channels? Perhaps a look in the manual may help, if we knew what electronics we're talking about.
May 19, 2010 | Audio Players & Recorders
I can barely hear sound even when turned all the way up
Turn-off all "surround sound" modes. Try listening to just a plain AM or FM talk station. Then you can check your speaker wiring. Some stereo programming can turn into nothing with certain surround modes, so make sure that your speaker wiring is correct by using the radio or CD player with it first.
Nov 10, 2009 | Harman Kardon AVR 120 Receiver
No sound in listening modes except pure audio and direct. Was working fine and just stopped one day. Connections are all good. Surround sound seems to be broken?
Aug 06, 2009 | Onkyo TX-SR804 7.1 Channels Receiver
Low sound when turned to AUX for surround sound
remember to turn the volume up on the cable box and down on the surround sound so you will get max audio input to the surround system and then adjust using the surround sound remote! good luck
Jan 11, 2009 | Panasonic SC-HT680 System
No sound from surround speakers
you have it set in stereo mode change listen sound to auto this way whatever way the signal is coming thru you will hear it
Jan 09, 2009 | Kenwood VR-405 Receiver
My Onkyo TX SV 535 Surround Sound wont work
when the stereo or mono listening mode is selected only front speaker and subwoofer produce sound--------make sure that speakers are configured correctly.
and you select surround sound in listening mode.
Aug 17, 2008 | Onkyo TX-SV535 Receiver
Help!!!!!
Hi Linda,
It is showing two because the source of the sound that you are listening is probably stereo only thus only two sound comes out. You could try to change the mode to 5 channel stereo or prologic or dts-6channel mode in the surround mode to hear your sound in all 5 speakers. best thing to do is watch a dvd which would use all 5.
Regarding a/b yes if your receiver supports it which i think it does there should be place for it in the back of the receiver.
good luck
smeags.
Feb 19, 2008 | Audio Players & Recorders
 Grubhead
Grubhead
Marvin
Marvin
