Question about Samsung Dryers
Samsung dryer dv331aer/xaa02 lights turn on, both switches on heating coil replaced, but it will not start
6ya staff
SOURCE:
localwonder
Michael Masters
  • 6784 Answers
SOURCE: Dryer will not start have replaced the heating element, door switch and on switch
hi, i recommend inspecting the terminal block that the power cord is connect to on the back side of the dryer. this terminal block may be faulty or, the cord could be lose and not connected properly.kindly, inspect this device that is located on the back side of the dryer for lose connections. if the termainakl block is in good conditon and, the power cord is screwed on tight, thsi iwll confirm timer fialuer.
replace the timer in this case.
Posted on May 20, 2009
hunter19_46m
Curtis Sewell
  • 7482 Answers
SOURCE: ge dryer model DVL223EA0WW service manual to replace heating coil
Try this website, they will have everything you need.
http://www.repairclinic.com/SSPartDetail.aspx?PartID=2512&Acc=1&PPStack=1
Good luck,I hope this helps
Posted on Nov 13, 2009
ftw1952
frank thomas wilson
  • 10319 Answers
SOURCE: dryer not heating
Check the moister sensor and relay
Posted on May 11, 2010
heatman101
D. Floyd Kolb
  • 43501 Answers
SOURCE: Dryer will not turn on
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The
Dryer is not Turning
Dryer Repair - The
heatman101
Posted on Dec 05, 2010
yuliealot
gilly Gill
  • 38 Answers
SOURCE: Frigidaire dryer not drying clothes
did u clean out the vents inside and the hose vent leaving the house? if so then, it could be the control nob
Posted on Jun 08, 2012
Samsung dryer model #DV328AERXAA. We replaced: 4 drum wheels, belt, light, heat coil, heat thermostat & fuse, thermister & fuse, and the control panel still no heat? starts then heat coil fuse blows
on the main controller board there should be some micro switches these a relay type and were out or get overheated, but if this is on gas. it can be the flame sensor https://youtu.be/VTnDslKW6y0 electric.
https://youtu.be/7KaMwV85qUI Gas
Apr 24, 2018 | Samsung Dryers
Samsung dryer wont spin and the control board clicks when i press the start buttonModel DV331AER/XAA
start by pulling off the top and see if the belt is broken or not. some units turn off power to the motor is the belt is broken. a common problem
Sep 15, 2016 | Samsung Dryers
My samsung DV331AER/XAA 02 clothes dryer will power on but won't dry
Hello Sunny;
My name is Peter. I am a retired field service appliance technician.
1.) Poor air flow:
If your dryer is plugged up with lint it will not heat. In the back of your dryer is a air distribution manifold. It is elongated and round at the bottom. There are just a couple of screws holding it on. Unplug your unit, remove the manifold, usually at the bottom is where it is plugged. Also clean around the blower wheel.
2.) Bad door switch - If the drum is not turning.
If you hear a clicking sound when you push on the plunger the switch is good. If not:
Remove the top cover. There are two clips in the back, one on the right and one on the left. Using a spatula or thin blade push in to release, then slide the cover back. You should be able to see the door switch. Remove the two wires from the switch. With a multi-meter set on the lowest ohms check the switch. If you get a reading other that '0' the switch.
Part #: DC64-00828A - Cost: $16.00
3.) Thermostats:
This is located inside the dryer on the side of the electric heater assembly. You must ohm this out as above.
Part #: DC47-00018A - Cost: $21.00
Part #: DC96-00887A - Cost: $11.00
4.) Bad heater element.
Ohm this out as the above.
Part #: DC47-00019A - Cost: $65.00
5.) Bad motor drive pulley contact switch - If the drum is not turning.
Part #: 3405-001077 - Cost: $7.00
Ohm this out as well while holding the button in. Once again should read '0' if good.
Dec 08, 2014 | Dryers
Samsung will not turn on
getting power from house outlet? check terminal block with multimeter for voltage? then check thermal fuse. door switch, belt tensioner motor switch etc
Jul 18, 2014 | Samsung DV331AER Dryers
Samsung gas dryer dv331 will power up but won't run. The lights blink and the unit clicks one but won't start.
Try spinning the drum by hand. If it's really loose, then you need a new belt. I recommend getting this done by a professional, or you watch a youtube video. It takes a standard whirlpool belt.
Nov 03, 2013 | Samsung DV331AER Dryers
My samsung dryer model no DV328AEWXAA has suddenly lost it heat .it just blowscold air
ALWAYS UNPLUG YOUR DRYER BEFORE ATTEMPTING TO DO ANY WORK ON IT.
Check to make sure you are getting full 220 Volt power to the dryer, if you are then:
Check your Wiring
Often the main wiring connection from the house, at the dryer, burns and the connection breaks. If this has happened to your dryer, you need to replace the power cord and the terminal block inside the dryer to which the wire is attached.
Check the Door Switch
If the door switch or the door-switch actuator is defective, the dryer won't work and you need to replace the failed component. The switch is inside the dryer main housing near the door frame. Sometimes you need to raise or open the top or front of the dryer to reach the switch. Check for continuity you should have none with door open, and should have a reading when closed. If not replace the door switch.
Check to make sure you heating problem is not a lint build up in the discharge hose or the dryer,as this condition can cause heater/thermistor problems such as overheating of the heating coil leading to failure of the coil and burnout of the thermostat/thermistor due to overheat.
Remove the back/or front just under the door of the machine and try to locate the air duct going from the blower to the drum. Normally inside/outside the air duct you will find the heating coil and the thermostats/thermistors. Once you have located the heating coil, remove the two wires from it and check the coil with an ohm meter across the two terminals of the coil.
You should read continuity across the terminals, if not you will need to replace the coil as it is faulty.
If the heating coil is ok, then:
You can check the thermostat/thermistor one at a time by removing the two wires and taping them together with electrical tape and running the dryer to check to see if the element is red or not,
or with an ohm meter check the two terminals of the thermostat/thermister
after you have removed the wires, the thermostat/thermistor should have/show continuity across the terminals.
If the coil heats up, or the thermostat/thermistor shows an open circut
then replace the thermostat/thermistor as it is defective.
If it overheats the dryer will not operate properly.
It's located on the blower housing.
It cannot be reset. A vent clogged with lint can cause it to overheat.
You can test it with an Ohm meter/continuity checker, if no continuity,
replace it)
DO NOT LEAVE THE WIRES TAPED TOGETHER AFTER THE TEST.
This could cause a FIRE, as you have removed the safety of overheat from the machine.
Right after replacing a dryer element, always run the dryer on 'air fluff' / 'no heat', and go outside to verify there's plenty of air coming out your vent system.
If the vent's clogged, that new element can burn out very quickly.
This is a FREE answer, Please rate me
Jan 05, 2011 | Samsung Dryers
Samsung dryer smells like gas
Replace the operator coils. They are intermittant. Typical operator coils look like this:
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Nov 27, 2008 | Whirlpool GGQ8831L Gas Dryer
Dryers Logo
46 people viewed this question
Top Samsung Dryers Experts
Marvin
Marvin
Mike
Sheldon Dedek
Are you a Samsung Dryer Expert? Answer questions, earn points and help others
