SOURCE: Poulan Farmhand chainsaw chain tightens too tight for motor to move chain
Make sure the chain is not over tightened. When adjusting the tightness, ensure there is at least 1/8" of looseness by pulling up on the chain in the middle of the bar and releasing it. If a chain becomes overheated because of leaning on the saw when the chain is dull, or lack of oil on the chain, it may expand in the track and not turn freely.
Marlyn, Mountain, Ont. Canada
SOURCE: poulan Super 1800 16" chainsaw .
Hi dortfran,
My name is Dennis and I hope to be of assistance.
This sounds like a kink in the chain and I would try a new chain because this can be a very small kink and very difficult to find and straighten out. If you must put the chain saw in a vise by clamping the bar and run the chain back and forth from the sprocket to the bar grove under operating tension and locate the misalignment at the bargrove. Now you have located the problem but the fix is still sweat away, and with some luck you may be able to spring the chain straight and have the link flexable to opporate without a hitch.
Glad to be of assistance. Please rate the solution because i can learn from your rating.
Thank you
Dennis
SOURCE: HOW TO INSTALL A NEW CHAIN ON POULAN 16'' BLACKHAWK CHAINSAW
hi likniz
unlock the lock nuts,take off the chain cover,change the chain,adjust the screw tightening chain,back the cover and the lock nuts.
best wishes savumihai71
SOURCE: chainsaw wont oil the chain and bar it is a poulan 2000 woodsman
It's probably the oiler check valve located on the crankcase just in front of the clutch. You will probably need to remove the clutch and sprocket to get at it.
SOURCE: Poulan Pro Chainsaw chain tensioner is junk
Hammy if you scream loud enough Poulan may foot the bill for this.
Poulan “PP4620AVX” IPL (exploded parts list)
We are going to replace this page 2; item 70
http://weborder.husqvarna.com/order_static/doc/NIUS/NIUS2009/NIUS2009-PP4620AVX-545103410-952802169.pdf
Poulan “PP4620AVHD” OM
http://weborder.husqvarna.com/order_static/doc/NOUS/NOUS2005/NOUS2005_545047502.pdf
Poulan “PP4620AVHD” IPL
http://www.ordertree.com/modelinfo/PWE/PP4620AVHD-Gas-Saw/75.PP4620AVHD-Gas-Saw.1.59.1.html
With this; “Handle, Chassis & Bar Assembly” print; item 67; ChainBrake Assembly; $21.83.
You also need;
This is the configuration professionals have used forever. The only thing to remember here is to hold the nose of the bar up when adjusting and tightening the bar nuts.
If you have more questions or need additional help please reply below and I will get back to you. Good Luck. HTH
Lou
Thank You for using FixYa.
Testimonial: "Thanks -- that's exactly what I was hoping to find. It's wonderful to be able to tap into expertise like this. Very Happy!"
