The model number you showed is a part number the model number is usually on the cabinet when you open bottom drawer or door, F2E0 is a control panel problem, stuck button or bad connection
The F2 E0 error indicates a short at the key pad or a wiring issue between the control board and the keypad. Try pressing Cancel. Next turn off the range at the circuit breaker or unplug the range. Wait at least a minute before returning power to the system. Check if the error returns within a few minutes. Disconnect the power again and check the wiring between the control board and the key pad (if these aren't a single assembly). If the wiring connection is loose, secure the wires. If there is corrosion at the contacts, use a contact cleaner on the unit. Let the contact cleaner dry before connecting the power again. If the wires are damaged, replace the broken wires.
If those steps don't resolve the issue, replace the key pad or keypad and control board depending on the unit. If the error returns after replacing only the keypad, then the control board has to be replaced.
Please check the model number of the range. Current Whirlpool range models start with 3 or 4 letters, 2-3 numbers, another letter and another letter and 2 more letters. W10400397B could be a replacement part number for some specific item inside the range or the serial number. It isn't a valid Whirlpool part or model number at https://www.whirlpoolparts.com/ or https://www.partselect.com/Whirlpool-Oven-Parts.htm .
I hope this helps.
SOURCE: Kitchenaid glass top electric range
I have the same problem...stuck key err F2E0
Can any one please tell me where is the sensor? I mean which part of the oven have sensor, is it inside or under the button control panel?
SOURCE: kitchenaid electric range yker1201 with f2e0 error
F2-EO indicatwes a shorted key pad. Electronic parts on ranges sometimes have warranty for five years (may only cover parts) so check your owners manual to see what your warranty is then call for service. It is a good idea to save reciepts of repair for future reference if neccessary.
SOURCE: Start Button Failed on Whirlpool Electric Range Model GY396LXPQ02
It sounds like you have an oven problem rather than a start button problem. Is there an error code? If so list your model and error code on a search engine and you will find error codes. Or you can just list make model number and error codes and you can find a chart of Whirlpool error codes. I have done this with no problem. That should tell you the exact problem and things to try.
It may be neither issue you mentioned. It could be a bad element or a short.
SOURCE: whirlpool electric oven problem
thermal fuse to board blows, relays turn fans off, the thermal cut out on rear of oven kills element. change both fuses, install new style oversized blower.
SOURCE: Kitchenaid Architect Electric range model
Hi
Thanks for using FixYa. Error F2-E0 on your kitchen aid means that the keypad is shorted and to resolve this issue you’ll have to replace the electronic range control/clock (ERC). Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
All parts come with a 365 day, any part, any reason return policy.
