Question about Watches
How do i change time on wearfit smart bracelet
I need instructions for setting up a z18 smart bracelet
search google online Shop. I think you can get it
Feb 17, 2018 | Watches
How to set up PBTW155-ASST1 proscan smart bracelet
don't know how to start using it
Jan 19, 2015 | Watches
Dear Sir, I have one of the above Omega Seamasters which was bought in June 2007. Since then the bracelet has fallen apart 4 times now and Swatch want me to pay for a new one. Is this normal for a bracelet...
Hi dunphysteven
It is not normal that the bracelet falls so often.
There seems to be an issue with the product. However the warranty period in most cases is limited to 2-3 years, which unfortunately has crossed in your case.
Therefore in this case u need to pay for the bracelet.
Alternatively you can sell your watch on ebay or some other similar site with the mention that bracelet is an issue.
Hope this helps you.
Regards
TDCL
Jan 29, 2011 | Omega Seamaster 300M Mid-Sz 2551.80.00...
I need to buy new bracelet
mcdevito75 here, BEST BET for your Ebel watch, look for a small watch repair shop in your area, to order a new bracelet.
Jul 13, 2010 | Ebel Type E Stainless Steel Rubber Strap...
After buying this model watch bracelet links are rusted and torn with one year of purchasing. When i took that watch to the show room where i purchased. They kept it for 40 days saying that they has to...
mcdevito75 here, Many watches built today are not comming out with replacement Bands (straps, Bracelets) from the factory, the cost of makeing and keeping extra bands on hand is too high, they should at least have a few extra links to replace worn ones. Chances are your warantee is over on the watch and in that case, you"ll have to find another band, Bracelet on your own. Best Bet, visit a small watch repair shop in your area for another bracelet, band, Strap.
Jun 29, 2010 | Watches
How to adjust expandable bracelet pleaseI would like to remove links to make it smaller.
If you are ready to take that risk, here is how you can do that.
First- get watch on your wrist and by squeezing the bracelet count how many links you have to take out to make it tight enough (say 4 for example).
Check the sides of a bracelet. You will notice that the upper band metal is flipped over the bracelet side. Take tweezers or small pliers and unbend one of these. Try to do as little damage as possible.
When it's done, you will see two metal staples inserted into the bracelet. You have to pull them out. While pulling out, remember how they where positioned, as you will need to drive them back in the same manner.
So, when the staples are out, do the same on the other side of bracelet. Now you have bracelet in two halves.
Count off 4 links and undo the staples in joint of 4th and 5th link in the same manner as previously.
When links are out, take the staples and drive them back into the bracelet joining two ends together. You have to do that exactly the same way and position as you took them out.
When all staples are in place, bend the metal back over the bracelet sides.
BE WARNED: as you gonna do it first time, be ready that you can damage the bracelet or can not put it back together.
Good luck.
Jul 29, 2009 | Casio Watches
Self-adjustable bracelet watch
Check the sides of a bracelet. You will notice that the upper bands metal is flipped over the bracelets side. Take tweezers or small pliers and unbend one of these. Try to do as little damage as possible.
When links are out, take the staples and drive them back into the bracelet koining two ends together. You have to do that exactly the same way and position as you took them out.
When all staples are in place, bend the metal back over to the bracelet sides.
Good luck.
Rate me, please.
Mar 19, 2009 | Timex 2J611 Watch
I have a bracelet link bracelet expansion bracelet watch I need to remove some links
Good luck
Dec 21, 2008 | Timex 2J611 Watch
Watch strap to loose
Good luck.
Dec 18, 2008 | Watches
Watches Logo
Top Watches Experts
Janelle Schoonover
Janelle Schoonover
Marvin
Marvin
Are you a Watch Expert? Answer questions, earn points and help others
