Question about Advance Audio Players & Recorders
Thorens TD309 with TP92 tone arm - how to properly adjust anti skating.
Would like to see factory drawings of tonearm and how magnetic anti skating on this arm works Thanks in advance
6ya staff
SOURCE:
Anonymous
  • 7 Answers
SOURCE: Tone arm skip back.
You most likely have broken balls,,, lol yes balls bearings are most likely broke you might have to replace your arm.. about 80.00 for the part
Posted on Oct 19, 2007
ctf1800
Cary Farah
  • 4402 Answers
SOURCE: Technics 1210 tone arm is really stiff.
sounds more like the grease is hard
Posted on Jan 21, 2008
djtatty
T-Comtech Repairs
  • 417 Answers
SOURCE: tone arm pulls back on my technics 1210s
your needles gone.or you've moved the tip by touching it.
try & twist the tip back straight.
A LITTLE TIP FOR YOU ....u should never wipe or
touch the tip of a needle with your fingers coz the greese off your skin ***** them.blow it or use a little fine brush.
Posted on Aug 08, 2009
methleykev
  • 135 Answers
SOURCE: Specs for Technic Sl1210M5G Turntable
Anti skate should be set the same as the weight, i.e 3 gram of weight = 3 on the anti skate.
http://stores.ebay.co.uk/methleykev
Posted on Jul 05, 2010
STYLUSCITY
Styluscity
  • 271 Answers
SOURCE: Marantz TT221 turntable anti-skating problem
Hi, sounds more like tje stylus tip is gone and therefore the needle isn't holding to the grooves rather than a tracking weight or anti skate problem. Styluscity@gmail.com
Posted on Sep 15, 2010
Tone arm adjustment for 1200m3d
Reduce anti skate setting . Round knob with numbers on it at the base of the tonearm. Cheers john. styluscity.com
Nov 19, 2011 | Audio Players & Recorders
My tone arm has suddenly started skidding across the record surfaces. Its a brand new turntable and was fine till yesterday !!!
Generally the cause is one of 3 things. 1 Damage to the stylus or dirt. 2 Lack of pressure to the stylus. 3 Anti-skate control set to low.
First check the stylus you should feel it sticking in you finger a bit. 2 Has the weight on the end of the arm become lose? Adjust for the correct tracking weight of the cartridge. 3 Check the manual for what the anti-skate control should be set to.
Feb 23, 2011 | Technics SL-1200 Turntable
May 19, 2010 | Technics SL-1210 Turntable
How to adjust automatic anti skating system on a PE 2015 record changer? Had to replace magnetic cartridge and needle by an other system, and the arm pulls too much towards the external side of turntable....
Elektrotanya for electronics experts search for the word processing that will change to GET MANUAL after a while you have a manual but there should be a tool neccesay for the arm or Tone arm geometry knowledge or almost there was a tool for the novice user there delivered with the turntable because the error angle setting for the needle special if you replace the complete element with needle
Jun 11, 2017 | Audio Players & Recorders
Tone arm gets caught up and skips repeatedly
Is there a counterweight on your arm or is the an adjustible spring setting? You need to move the counterweight toward the needle. You dont need much but the needle end needs to be heavier than the back side. If your anti skating is a magnet ... reduce the force on that as well.
Let me know what happens.
a
Sep 25, 2009 | Audio Players & Recorders
Tone arm pulls back on my technics 1210s
Aug 04, 2009 | Technics SL-1210 Turntable
Sears Tape deck/Turn table skipping!
Hi the pennies will mess up the stylus. There should be an anti skate setting at the back of the turn table, a round adjustable bit with numbers, increase the anti skate and then use the balance weigth (weight right at the back of the arm that turns to get the weight right. Set the anti skate with the tone arm light, then increase the weight a bit. Hope that helps
Jun 14, 2009 | Technics SL-1210 Turntable
I balanced my tonearms correctly. i think .. but the stylus jumps off the record and when i back spin (cue) the needle skates drasticly. can you walk me through the balancing proceedure and tell me how to...
Balancing the tone arm is a two step process. Set the needle weight adjustment to zero(0) and make sure that the tone arm is balanced. It should rest horizontally without touching anything. Next, set the needle weight (usually 1.5 grams). Both adjustments should be on the rear of the tone arm. That should cause the tone arm to drop toward the record and have the correct pressure for the needle. Also, check the anti-skate adjustment. If that is off, the behavior you describe will occur as well.
Dan
Jul 21, 2008 | Technics Audio Players & Recorders
Well on my technics MK2 1210's, the little anti sketch settings and all the others probably arent set to what they are supposed to be, because my needle arm keeps jumping :P could someone tell me what all...
There are two main things that will influence the anti skate settings.
1) The Headshell Weight and Balance
Firstly, check the data sheet for the cartridge and stylus you are using. It should tell you the correct weight setting which will vary from one cartridge and stylus to another. If the stylus is set too light, it can skate across the disc. This can damage the disc and the stylus. The sound will also be thin and it is likely to distort on high frequencies. If the weight is too heavy, it will not jump but will definitely damage the disc.
If you are a serious vinyl user, get yourself a tone arm balance. This is a device that you place on the turntable and you rest the stylus on a plate which is marked in micrograms. You place the stylus exactly at the correct weight marking and then make adjustments to the turntable settings until the tone arm is balanced. It's easier than it sounds!
If you don't have the data sheet for your cartridge and stylus and cannot find it online, use an old disc that you don't mind damaging, set the weight on the light side and gradually increase the weight until it stops skating.
2) Platter Levelling
Secondly, you need to make sure your turntable us on a level surface. If you are a purist, use a spirit level. to do this.
There are other things that can cause skating and jumping, especially if you use the turntable as a DJ. For example, vibration (caused hopefully by dozens rocking to your music). DJs will often increase the headshell weight very slightly to overcome this and I have sometimes placed the turntables on a thick rubber sheet such as carpet underlay to improve shock absorption.
Mar 26, 2008 | Technics SL-1200MK2 Turntable
Philips 777 stylus force adjustment
LM15 has an elliptical stylus so 1,5 - 1,8g should be sufficient, and also dial the same number on the anti skate for elliptical stylus and go for it
Dec 02, 2007 | Philips Audio Players & Recorders
37 people viewed this question
Top Advance Audio Players & Recorders Experts
Paul Carew
 Grubhead
Grubhead
Andrew Taylor
Andrew Taylor
Are you an Advance Audio Player and Recorder Expert? Answer questions, earn points and help others
