Question about Kenmore Microwave Ovens
Need a replacement for kenmore 721.80012401 microwave..can be any brand in s/s. Unit is 15 yrs old
5 Suggested Answers
6ya staff
SOURCE:
MicrowaveSvc
William Miller
  • 9179 Answers
SOURCE: kenmore microwave 721.80412500
The owner's manual should spell that all out.
But if you don't still have yours, you can download one via Sears' "Manage My Home" site here. While it's free, you will have to register.
(You *may* be able to download it here without logging in. If not, go ahead and register. It's free.)
Posted on Sep 25, 2008
MicrowaveSvc
William Miller
  • 9179 Answers
SOURCE: kenmore galaxy microwave model 721.80002 1500 watts does not heat
With the symptoms you have, I would most strongly suspect a shorted high voltage rectifier diode or a bad magnetron, or a loose and possibly corroded connection on the magnetron's terminal.
The diode is a fairly cheap fix, and the mag will cost more.
If you or someone you know decide to look into it, we have critical safety information and disassembly information at our site, and our link is at our listing here on FixYa.
There should be a "mini-manual" (tech sheet) hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, testing, and locating components.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
If you don't find yours, or if you want to look at it without disassembling the oven, you can download it here.
Here are some links you or someone you know can use for test help, but read their safety warnings first:
http://www.gallawa.com/microtech/diode.html (if it's not shorted, it's probably okay)
http://www.gallawa.com/microtech/mag_test.html
http://www.gallawa.com/microtech/xformer.html
Posted on Dec 22, 2008
Anonymous
  • 31 Answers
SOURCE: lost heat on microwave ,everything else works fine simple fix?
Inexpensive fix yes, but quite dangerous as you have to either replace the High voltage Diode or the magnetron depending on what has gone. Most often it is the Diode as that is fed a few thousand volts and anomolies such as a surge in current cause it to blow(popping sound) You can also check the fuses and if lucky it is just a fuse, but a fuse very seldomly just blows as it points to an underlying fault such as magnetron , capacitor or Diode. Have a service man attend to it unless you know what you are doing as you are dealing with lethal voltages and current even after the microwave has been switched off.
Posted on Aug 01, 2009
jsrock516
Jeff Rockwell
  • 5911 Answers
SOURCE: The door handle cracked from the door. The unit
Or, if the handle itself is the only piece damaged, you can simply replace the door handle.
On MOST microwave ovens, you just have to remove the inner door panel that goes around the perimeter of the glass. The panel is pressed in place and can be removed by using a small screwdriver or putty knife and carefully insert along the seam of the inner panel to pry the plastic up. Work your way slowly around the perimeter of the glass to pop the panel loose. Use care not to pry against the glass. The glass is tempered and also has an RF shield that shields you from harmful RF radiation.
With the inner panel removed, the door handle screws are visibile and can easily be accessed with a screwdriver. Simply remove the broken handle and install the new one. Re-insert the inner door panel, gradually working your way around the perimeter of the door glass to ensure it snaps back into place and seats properly.
This repair can be done with the door in place, or you can remove it for easier access. If you decide the remove the door, open it all the way and lift straight up at the hinges. The door will lift off of the hinge pins. On some microwaves, you may have to remove the upper grill cover over the door (if equipped) to accommodate door removal. Place on a hard flat surface with some towels under it for padding. This protects the door facing from scatches.
NOTE: Some doors have a hinge pin that needs to be removed, or screws holding the door in place at the hinge.
You can view an exploded view diagram of your microwave at any of the following websites for reference: searspartsdirect.com pcappliancerepair.com appliancepartspros.com Just type in your model number and locate the parts listing for the door. If you have any questions, or require additional assistance, please let me know. I hope this helps you.
Posted on Dec 23, 2009
My Samsung microwave model # ME16H702SES. IS not heating anything. This is the third microwave that does this to us. Any suggestions?
VERY BAD LUCK. Cost wise you might as well replace the unit. Try a Panasonic brand, mine is 15 years old as was the last one before that, very durable.
Mar 28, 2017 | Samsung Microwave Ovens
How do you replace the damper switch on a Kenmore microwave, model 721.86013010
Microwave Vent Damper Replacement - GE ... - YouTube
? 3:15
https://www.youtube.com/watch?v=9sQco-DIqQ8
Nov 25, 2013 - Uploaded by RepairClinic.com
The most common reason for replacing the vent damper is if it i... ... video is applicable to the following brands ...
How to change the direction of a blower fan for an over the ...
? 1:45
https://www.youtube.com/watch?v=yhvuNOVN0R4
May 8, 2012 - Uploaded by Sparky Channel
For a great price on a Whirlpool microwave: Amazon.com: ... Howto change the direction of a blower fan for ...
Kenmore Microwave Parts - RepairClinic.com
Jan 21, 2016 | Kenmore Microwave Ovens
Microwave stopped working what can possibly be the problem
If it lights and the fan turns on, then most likely it is the magnetatron or heating element. It can be replaced.
Aug 19, 2014 | Kenmore Microwave Ovens
I was cooking food for 1 minute and it just shut off after approx. 30 sec. There are no lights or power now. The outlet is fine. The unit is 4 yrs old.
Check your other appliance. You may have tripped a break. If they are all functioning, and you have no dead outlets in your kitchen, then the unit will need to be serviced. Hope it's the breaker.
a 1200w microware will draw 10 amps all by itself. Your outlets are most likely on 15 amp breakers, so it wouldn't take much amp draw from another kitchen appliance to trip the breaker.
May 11, 2011 | Dacor DMT2420SS Microwave Oven
How to replace hv diode for gt4175sts microwave
you must !!!!!!!!!! discharge the capacitor first or it will kill you !!!!!!!!! use a discharge wand then cut out old diode and resolder new one ..
ps tell me why are you replacing the power diode in 15 yrs working with microwaves ibe never seen one blow
Dec 02, 2010 | Whirlpool GT4175SPS Stainless Steel 1200...
Microwave oven just quit working....is there an internal fuse that i can replace?
Yes, but chances are it is not the fuse. I just fixed an LG with the same problem by replacing a thermostat, that went bad. On this model the power goes through a filter and then 2 thermostats before it will power up the board. If you are not familiar with electronics and the unit is over 3 yrs old I would just buy a new one. my part was $4 but to have a tech replace it will probably cost you $100.
Feb 27, 2010 | Kenmore Microwave Ovens
MICROWAVE GOLD MICRO DOES NOT OPEN
sound likes the push button spring broke or popped out of place. if you unplug unit remove all screws going around the back edges. take panel off all the way around ,then you will be able to check spring and bbutton. the ones ive worked on the puch button cradle is usually broken and can be replaced as long as its not 20-30 yrs old.do it yourself 15-30 dollars in shop repair 65-95, in home service around 85-145.00 dollars. depending were you live.
Sep 16, 2009 | Whirlpool RMC275PD Microwave Oven
Microwave stopped heating
I had the same oven for one and a half years and had the same problem. Had the sears repairman come out and he said the magnetron burned out and needed replacing for $285. It was never under warranty with the warranty that came with oven. I couldn't believe it! We had an independent repairman look at it and he found a design flaw that causes the magnetron to blow. If you replace the matnetron (megnatron?) it will work for awhile, maybe, but then just need to be replaced again. It's cheaper to buy a new microwave. In fact, I got out our old microwave that's over 20 yrs. old and still works--just isn't as fast and as new ovens. Good luck!
Jul 22, 2009 | Kenmore Microwave Ovens
Which brand microwave oven is best in the market
That kind of depends what you want. Kenmore, Whirlpool and Fridgidare are the best value. Maytag, Amana, Jenn Aire are a little higher end. LG and Electrolux are the higher end. When it comes down to it most of them have some of the same components. Keep it simple. The more bells and whistles, the more likely it won't last. Sometimes the cheapest ones are the best. Personally, I have a countertop unit by Emerson. 10 yrs old, no problems.
Mar 25, 2009 | Samsung 80092 Microwave Oven
Microwave touchpad don't work
it can be repaired , but i would try to get an estimate for repairing the or replacing the chip board that controls the time and start up of microwave , if its going to be more than it woth to you , then you would ofcourse would want to get a new one , and being that is ten yrs you might just want to get a new one anyway .
electech
Nov 26, 2008 | Kenmore 62622 Microwave Oven
Microwave Ovens Logo
32 people viewed this question
Top Kenmore Microwave Ovens Experts
William Miller
William Miller
Gerry Harvey
Gerry Harvey
Are you a Kenmore Microwave Oven Expert? Answer questions, earn points and help others
